i need to change my cim due to a faulty clockspring
do i need my security code for my car and the donor security code?
where do i get my security code from i never got one when i bought the car used
http://www.vectra-c.com/forum/showth...pass-code-from
u cant use voucher discount by the way well they wouldnt let me use it anyway but speak to andy.i or plasma as it says
you need your V5 and go into vauxhall to apply for it. And yes you will also need it for the donor CIM UNLESS its been cleared already
Yes. You need to go to vx to get the car pass. If your buying a second hand CIM iirc it needs to be unpaired from the old car prior to fitting. I'm not sure if it can be unpaired when fitted to your car even if you have the old card code. Plasma or Andyl will know.
doesnt matter before or after as long as u have the pass for it![]()
i can get it without the v5
just need the reg n chassis number
so can i so whoppydoobut if the OP needs it he'll have to produce the V5
how do i get it with my chassis and reg??
