Results 1 to 10 of 21
Thread: water returning to header tank
    Regular Member vectra-man's Avatar
    Dec 2012
    basildon
    Vehicle : signum 2.2
    Default water returning to header tank
    Should water return to the header tank continuously or only when the thermostat opens??
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    From cold.
    Dec 2012
    basildon
    Quote Originally Posted by Das View Post
    From cold.
    Thanks for the reply. since I changed the thermostat sometimes it returns all the time and sometimes I need to either rev the car or squeeze the pipes for it to return. Before I changed the stat it was fine.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    When you start the car from cold it will rev at around 1000 rpm and the flow looks quite strong. As it comes off the cold start cuts out and the revs drop to around 750rpm and it drops to a trickle. I took couple of videos of this last week for another thread.
    Dec 2012
    basildon
    Thanks just see them it does start like that but the dwindles down to virtually nothing. I'm thinking This could also be the reason why my heating only gets hot whilst driving.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    If you mean it doesn't get hot when just sat idling from cold, say when your de-icing the windows, then yes. That is because there is no load on the engine, once moving more load = more heat, and at this time of year ambient temperature means a longer heat time too. If it is giving a good strong flow when the engine is rev'd I wouldn't worry about it.
    Dec 2012
    basildon
    When I drive the heater is brilliant as soon as I pull up at lights or on my drive straight away the heater turns warm until I touch the throttle again then it's nice and hot.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Does the temperature gauge drop? Might be the thermostat on the way out.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Dec 2012
    basildon
    Thermostat and housing just been replaced.
  1. header tank cap??
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 23:15
  2. water in header tank bubbling....why ?
    By manimal in forum Engine & Drivetrain
    Last Post: 28th September 2010, 18:41
  3. header tank cap
    By animal22 in forum Engine & Drivetrain
    Last Post: 6th March 2009, 14:52
  4. Header tank.
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2008, 21:41
