Thread: Another 150cdti spanner light
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Default Another 150cdti spanner light
    All,
    Spanner light stays on when I turn key before starting and all other lights go out as usual, then disappears after engine starts!!
    Any way of getting code before i have to take it to stealers to check codes?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by skip85 View Post
    All,
    I'm prepared to say either glow plugs or the glow plug relay. Mine is the the same - it goes out after engine starts. Had the codes read and it's the relay on mine.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by GazCDTI150 View Post
    Do you get any actual issues with yours at all?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Starts perfectly even in the cold temperature we've seen. Think it's just a daft niggle tbh.
    Wiltshire
    Mileage : 150000
    So how much is relay and is easy to do? - would or could this lead to poor MPG all of a sudden before spaaner light came on
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    Mines doing similar it only goes out once I start the car. I bought it from a vx main dealer so assumed it was right. Might take it back to them and ask about it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    It may affect mpg on cold start. The relay sits right beside the battery box, on the engine side. Never changed it.
    Mar 2012
    yorkshire
    I have the same problem too. fault on mine is one of the glowplugs not working correctly cant remember what the fault code was. no problems with cold start.
    Wiltshire
    Mileage : 150000
    Best take it to stealer but I will try relay 1st!
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    mine did this all it was was the car saying its got a fault on record got it cleared never came back!
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. Spanner light 5 times now exhaust gas light
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2009, 01:12
