Results 1 to 10 of 29
Thread: Hasn't worked straight out of the box, should i be concerned?
    Regular Member bbdp's Avatar
    Feb 2012
    Essex
    Default Hasn't worked straight out of the box, should i be concerned?
    Finally took the plunge and ordered the bluefin unit. Plugged it into the car this morning and it successfully stored the existing map but then the unit advised me to install the disc and upload the map to super chips.....the instructions in the box say this needs doing from time to time but i'm just a little concerned.
    Anyone else with a 2.8T had the same issue?
    The box the unit came in has my model on the outside so i know its the right one and the map uploaded successfully.
    Oh and the car started after i unplugged the bluefin most importantly! ;-)
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    im not sure why your concerned bud? i also have a blufin unit but i thought you had to download the info off your car 1st and upload it too superchips before they would send the remap to the blufin unit for you then to put on the car
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    I have the 2.8T signum super chips map ..not the Bluefin tho .
    I guess they just need the information from your car to make sure the map is absolutely correct .
    Deztroyer has the blue fin on his signum
    Beaten to it ..what Chris said lol .
    Feb 2012
    Essex
    Cheers guys. Not sure why but i had assumed it was all in the box so to speak and no interaction required than to plug it in, flash the ECU and start driving.
    in the meantime I've had a message from superchips to say i can DL the new map so have done that and just need to wait till i finish work to go and have some fun!
    Only took them 3 hours to reply as well which is pretty good i think!
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Once you have the bluefin map, make sure you get an RR
    Feb 2012
    Essex
    Quote Originally Posted by Ziggy View Post
    Whats an RR?
    All I can say is JESUS WEPT I NEED BIGGER BRAKES!!!!!
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    So it's worked then mate?
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    A rolling road. I had major problems with blue fin and my 2.8
    Feb 2012
    Essex
    yup it's definitely worked! Found a deserted road last night and stamped on the go pedal and scared myself!
    ziggy- what sort of problems did you have?
    Are you VXR Enough
    13 Post(s)
    What problems did you have fella cos I'm having some at the mo with superchips
  1. Steering wheel not straight, but car drives straight?
    By Danny.surname in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2013, 00:21
  2. has it worked ???
    By aledjones_lex in forum Signature & Avatar Testing
    Last Post: 2nd August 2010, 21:59
  3. I'm a bit concerned...
    By spoons in forum World Cup chat!
    Last Post: 22nd June 2010, 08:37
  4. now concerned!
    By twaiter in forum Diesel Engine related
    Last Post: 23rd June 2009, 15:44
  5. should i be concerned
    By glynn in forum General Chat
    Last Post: 25th March 2009, 22:41
