Results 1 to 10 of 17
Thread: Increasing mpg through bhp
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    Exclamation Increasing mpg through bhp
    Hey guys been having this argument with a house mate (motorsport student so "knows everything") for a while but how would a remap and bhp increase help me increase my mpg?
    I assume it would be through extending the power curve and smoothing it out but his argument is that just the increase in bhp will reduce my mpg. Surely a correctly applied remap and bhp increase should help my mpg.
    anybody know a definitive argument because I'm fed up of being called and idiot before I give him what for.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    To get more BHP you need to burn more fuel. You can optimize fuel consumption with a map, however for an increase in power you must burn more juice IMO.
    So in normal every day driving when the power ain't used you could probably increase fuel economy. On the flip side when booting it the consumption will be more.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    You'll maybe tend to change up quicker which the extra torque. Problem is you'll more than likely boot it with the extra power instead!
    Aug 2012
    Hartshorne
    Trim : SRI
    Yh and that's my exact argument. I want more power to play with but I also do excessive miles on the motorway just sat in cruise control at 70. Can't regularly afford to fly about everywhere.
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    At 70mph, you can not increase the fuel economy of the 1.9cdti or other engine with similar gearing as you are already happily driving in 6th gear. As stated, the only way to improve economy with tuning is to reduce torque/power by burning less fuel OR increase low down torque/power to allow a higher gear to be used at lower rpm, thus burning less fuel again.
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Well the real saving should come from changing up sooner, although there is debate on that reducing the life of dmf's. More vibration a lower revs. But at the very least cruising at 70 should use no more fuel. You need a certain amount of power to do 70. The car hasn't changed, so it's the same after a remap to overcome the friction of the road, air etc. Same power, same amount of energy therefore same amount of fuel. The savings imo are changing up quicker when accelerating, and down less when overtaking.
    But like I said, power is addictive, and I know when I come to remap mine, I'll still drop to fourth and just go past faster!
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    128 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    I haven't remapped my car for maximum bhp, but rather for low-end torque and economy.
    The standard mapping is a compromise between emission regs and fuel consumption. I've experienced better average fuel economy since making the following changes:
    1. EGR disablement
    2. 1-3 degree advance in start of injection at low-mid rpm and injection quantity
    3. Reduction in requested boost pressure in same area.
    4. Opening of VNT vanes at low iq (seems to reduce engine-braking thus allowing deceleration phase to begin earlier when approaching a hazard).
    Aug 2012
    Hartshorne
    Trim : SRI
    Makes sense. See I thought that if the car developed more power then it would require the engine to work less to achieve the same results?
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    Essentially you have the right idea. But you yourself work it less by keeping the revs down.
    Regular Member coolcat's Avatar
    Feb 2012
    bolton
    Vehicle : vectra
    Trim : sri
    Engine : 1.9 cdti 150
    Year : 08
    Mileage : 72000
    so basically unless you drive like your grandad in his austin A10 the 10 to 20% fuel increase is bull.
  1. Increasing ground clearance
    By Micknal in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2012, 13:06
  2. Increasing engine performance
    By p4ul5k1 in forum Engine & Drivetrain
    Last Post: 18th July 2010, 14:37
  3. 2.2 petrol - what's best for increasing performance
    By gokartin in forum Petrol Engine related
    Last Post: 16th May 2010, 20:20
  4. FAO Neutron. Increasing your engine power :)
    By Chocki in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 15:58
  5. Vauxhall increasing their prices...
    By LJ sxi-nav in forum General Chat
    Last Post: 4th February 2009, 16:35
https:www.vectra-c.comforumshowthread.php180035-Increasing-mpg-through-bhp
increase mpg on Vectra c
