Results 1 to 10 of 11
Thread: Tuning Box issues
    Plymouth
    Default Tuning Box issues
    Recently bought a tuning box from eBay - admittedly not one I've heard of - plugged it in tonight, only to find that all it seems to do is bring the idle revs up to about 1400rpm (constant) and make the throttle pedal completely non-responsive...
    Have a bought an expensive ornament, or am I missing something?
    The service light also comes on, along with the traction control light. Reset the ECU by disconnecting/reconnecting the battery but still no joy.
    Anyone any ideas?
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    150 or 120?
    I did the same thing after putting it back on my 150 after the MOT, the plug on the end of the common rail was the wrong way round, un plug it & flip it round, plug back in & hey presto.
    Jul 2011
    UK
    Year : 06
    If the plug on wrong way round it won't start mine wouldn't anyways. I keep away from boxes as it can do a fair bit of damage also I took mine off as I like my flywheel and when ya floor it it's not smooth it's although ya getting pulled back
    Plymouth
    It's a 150 - I took a look at the cabling but unless im mistaken the plugs are keyed so you can't put them the wrong way round...
    Engine : 1.9 CDTi
    Any picture of the connector and box?
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Trust me on this, unplug the connector from the box to the end of your common rail, switch it round & plug back in, then try it.
    Mine did exactly this, looked right, swapped it round & instant grin when pressing the go pedal
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Quote Originally Posted by marc vectra sri View Post
    Sorry Marc but that's absolute nonsense. If they damaged your engine there wouldn't be companies such as DT UK. They are proven to make great gains with small cost & ease to revert back to standard. Flywheel damage? I can't see how you're going to do that, and as for not being smooth, you only make the acceleration as rough as you make it. I do 1500 miles a month, yes I have a play every now & then, but there's no reason as to why having a tuning box is going to do damage to my car.
    Plymouth
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    That looks like the correct connector I think that end plugs into the yellow connector that plugs into the fuel rail and the other connector from the tuning box fits onto the fuel rail. http://www.vectra-c.com/forum/showth...-to-a-CDTi-150
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by JJ0063 View Post
    It's called torque the more torque that goes thru ya flywheel the more it's going to wear it away ask others on here prob the maim reason my gearbox went. As for damage all a tuning box does is make dikes readings and pushes a load of fuel into the injectors making the car over fuel so when u put ya foot down u get a load of smoke. Also damages the Egr swirl and manifold henice why when u get a remap u delete the Egr. U can put a blank on the Egr to stop damage.
  1. Tuning box clutch issues
    By Tennants in forum Diesel Engine related
    Last Post: 28th October 2010, 18:47
  2. DPF and EGR 'issues' with performance tuning
    By andrew hastie in forum Engine & Drivetrain
    Last Post: 10th December 2009, 19:15
  3. cdti tuning boxes and DPF issues!
    By ronnie63 in forum Diesel Engine related
    Last Post: 17th June 2009, 22:08
  4. Caterman/T-Tuning Tuning Box for 1.9CDTi 150 (Z19DTH)
    By CHRISRi in forum Parts for sale
    Last Post: 25th May 2009, 18:49
  5. Diesel Tuning UK Tuning Box FOR SALE CDti 150
    By sshooie in forum Parts for sale
    Last Post: 1st April 2008, 16:49
