Thread: F10 fuse? Crimp conector
    Dec 2012
    wolverhampton
    Default F10 fuse? Crimp conector
    Hey quick question
    im hooking some led strips i now alot of people say use f10 fuse for the live but what do i use to but the wire in the fuse socket? Is it somethink like a piggy back fuse? And what do i use to crimp it on the wire a loom connector?
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    135 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    You need a mini piggyback fuseholder mate with 2 fuses. The ones I've used come with a short lead and an inline crimp connector already fitted.
    I don't think the fuse in the picture is actually supplied so I bought a pack of 10 fuses from the same supplier at the same time.
    http://www.ebay.co.uk/itm/1807358205...84.m1436.l2649
    Dec 2012
    wolverhampton
    Thanks mate ... Why do you need to add two fuses? Should it only be one for one supply feed? Or and what amp fuse do i need
    May 2012
    135 Post(s)
    Mileage : 131,000
    I think you need 2 fuses due to the design mate, one fuse is to take the place of the one that would be in the socket if you were using it, and the other is to allow power to the piggy back flying lead.
    If all you are using the fuse for is LED strip lights, then you can put a low current one in, somthing like 2A would be plenty large enough fella.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    I just pushed a small spade connector into the live side of the fuse carrier then an inline fuse after that.
    Dec 2012
    wolverhampton
    Thanks for your input guys... Much appreciated
  1. Areial Conector
    By baldybrewer in forum Bodywork & Interior
    Last Post: 10th January 2013, 01:13
  2. 3rd injector conector
    By hippo in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 15:45
  3. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  4. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  5. fuse box ID
    By myelite150 in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2009, 13:17
vectra c f10 fuse
Vectra C piggyback fuse
opel vectra c f10 fuse
vectra c fuse f10
vectra c ignition fuse
vectra c piggy back a fuse
