Thread: Hand Brake
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    Default Hand Brake
    Hi All I have the dreaded M O T coming up and my handbrake lever nearly goes into the rear of the car when applied. Can someone point me in the right direction on how to adjust it. Thanks in advance
    Nottinghamshire
    You can't adjust it - it's adjusted automatically each time you apply the handbrake. Check rear disks and pads for wear. Otherwise consider stretched handbrake cables and/or faulty auto-adjust mechanism (part of the handbrake lever assembly).
    Oct 2010
    lincs
    Thanks for your reply it had new rear pads and discs 10.000 miles ago would they have worn down that quick
    Regular Member Exclusive BV's Avatar
    West Midlands
    trying sitting in neutral with foot on footbrake
    them with the handbrake button pushed in pump the hand brake up and down.
    this seems to tighten mine up, some thing to do with the automatic adjuster
  1. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  2. Hand Brake Adjustment
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 29th September 2008, 10:01
  3. Hand Brake Ajuster on 2.2 SRI ?? Where, How!!!
    By Fireyfella in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2007, 18:58
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
