Results 1 to 10 of 19
Thread: High idle revs
    Jan 2013
    Glasgow
    Default High idle revs
    Hi again. This time I need help with 1000 revs at idle, as before it was 850. Please help!
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    What engine
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Sounds like you're in limp mode mate. You don't necessarily see the spanner light. You'll need the codes read via a computer or try the pedal test trick.
    Jan 2013
    Glasgow
    Sorry, forgot to add 1.9 CDTI 8V
    Jan 2013
    Glasgow
    Don't have fault codes.
    Jan 2013
    Glasgow
    It is not in limp mode.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by Kaz View Post
    OK then. As far as i know thats the only reason for a steady 1k revs at idle.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Did you change anything after it was idling at 1400 (your last thread)?
    Jan 2013
    Glasgow
    I had to re solder few wires as they were snapped but after that car ran brilliant. I was albe to clear all faults and none come up again.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Check your alternator if its not producing enough voltage ECU will up the rpm to compensate
  1. high revs
    By andy_richmond in forum Engine & Drivetrain
    Last Post: 12th October 2012, 18:43
  2. idle/low revs
    By srikev in forum Engine & Drivetrain
    Last Post: 2nd October 2012, 19:21
  3. high revs when hot
    By mentor in forum Engine & Drivetrain
    Last Post: 26th May 2011, 12:36
  4. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  5. Replies: 6
    Last Post: 5th September 2009, 14:01
https:www.vectra-c.comforumshowthread.php180006-High-idle-revspage2
vectra c high idle revs
