Thread: cd-2 into 1 don`t go
    Oct 2006
    spalding
    Default cd-2 into 1 don`t go
    the daughter has tried and now both discs stuck in, not in a vec but a picaso. any ideas on how to get them out?
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You'll have to remove the unit and dismantle it, just don't let your daughter do it...
    Oct 2006
    spalding
    Quote Originally Posted by nutron View Post
    i was hoping to not have to take the unit out but if that`s the only way i guess i`ll have to. mrs only popped back into house and daughter needed her dancing music on, she`s only 3, bless her??????
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Yep, pop out the unit, take the lid off the top & try to presuade it out with a bit of leverage. Better still if you can remove the cd deck from the unit you should be able to pull the disc out with a pair of long nose pliers.
    We had a unit in for repair once, not only were they not convinced it had a problem not playing a cd after they'd jammed two discs in they succesfully managed to try a third time & get that completely inside. I guess they thought it was magically making the discs disappear!!!
