Thread: Is my CAT goosed?
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    Default Is my CAT goosed?
    Hi team,
    Kept getting a v strong smell in the car and decided to investigate. Looked under the bonnet and saw smoke coming out from somewhere down low. Jacked her up and saw this
    Is my CAT goosed?
    PP
    Regular Member rfc52's Avatar
    Aug 2012
    Stonehouse
    Vehicle : vectra
    Trim : 1.9cdti sri 150
    Engine : diesel
    Quote Originally Posted by pompey-pimp View Post
    Hi team,
    Is my CAT goosed?
    PP
    i get the same issue but i have a split in my fron flexi pipe.
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
    The flexi pipe is absolutely fine. It is definitely coming from the CAT. Will take it out for a good blat shortly to give it a good thrashing
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    if anything is good for it a good long run where it can be constantly at a high temp will help clear it out.. Kill or cure you could say..
    Are you not getting any fault codes relating to emissions?
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
    No emissions fault codes only throttle actuator which I've had for about 18 months. The problem is it fills up the engine bay and this is then sucked in the car. Might take a drive towards southampton and give her a blow out. The Mrs only drives about 5-6 miles each way to work so not getting up to Temp. DPF is currently 102% saturated. When driving along it's not too bad but as soon as you stop it comes in
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
    Oh and idling has become a little lumpy of late as you can probably tell in the vid
    Jun 2009
    South Coast
    you may want to drive it further than that to clear it and do a dpf regen.... plus if you go near Southampton don't forget to pack your stab vest. lol
    from that vid though it does look like you have some sort of exhaust leak, there is also an awful tractor like noise coming from it as well
    Nov 2009
    Fareham Hampshire
    Engine : 2.0 d
    Year : 2010
    Went from mine to Fawley and it cleared the DPF to 8%. No smoke coming from the area. Went for a brew round a mates house and on starting up smoke again
    For trips to Southampton you also need a pocket translator
    Jun 2009
    South Coast
    hmm hopefully somebody will come along with a tip who is more familiar with that engine.. shame its not in the correct section as you could have had a definitive answer by now..
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Looks like oil dripping on the exhaust
  1. DPF Goosed.......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 27th July 2012, 13:43
  2. Is my DMF goosed
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 19th November 2011, 21:57
  3. goosed or not
    By andy76 in forum Engine & Drivetrain
    Last Post: 11th March 2011, 18:28
  4. Locking Key Goosed !!
    By JohnWilson in forum Troubleshooting
    Last Post: 2nd January 2011, 15:25
  5. gsi 3.2 auto box goosed
    By muller73 in forum Engine & Drivetrain
    Last Post: 12th February 2009, 12:56
