Thread: vacuum pump cdti
    Jan 2012
    Silverstone village
    Default vacuum pump cdti
    Hi what is the pipe that. Goes from the vacuum pump with a short hose that goes 10cm onto another metal pipe down the front of the engine, believe this pipe then goes round the side of the engine to the back?
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Vacuum pipe? Yours split or damaged...
    Jan 2012
    Silverstone village
    Quote Originally Posted by leemarksmith View Post
    Yea the end is cracked and seems to be letting a very small amount of air in, do you know what hose I should get ?
    thanks in advance.
    18 Post(s)
    Mileage : 110k
    There's mixed info on here of 3 or 4mm, but Paulvectrac measured his and it was 3mm...
    Ive just changed mine for 3mm and its a very tight fit on the engine side, any off eBay will do, I have some spare somewhere, I can post you if your in no rush, just not sure when I'll get to post as my car still stuck down drive with snow
  1. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
  2. Vacuum Pump 1.9 cdti 120
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:39
  3. EML - Vacuum Pump ?
    By matiny2k in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 20:53
