Results 1 to 10 of 20
Thread: led conversion
    Regular Member baines23's Avatar
    Oct 2012
    Dudley
    Vehicle : 2004 sxi
    Engine : 1.8
    Smile led conversion
    Hi all, wanted to know what sort of prices, would i be looking at for a full led conversion? as i would do most things my self ,but this seems a bit tricky, reading several posts ! as i would not be good at keeping a steady hand, any info would be appreciated .
    Regular Member Yenyaw's Avatar
    Feb 2012
    Hemel Hempstead
    Hi Mate, have a word with Marc Sri i think his username is on here, he has done mine, and reasonable price too, im well chuffed, getting him to get the speedo and other bits finished soon
    Regular Member farley2708's Avatar
    antrim n.ireland
    http://www.vectra-c.com/forum/showthread.php?t=134257
    start with the passenger door switch 1st,only 4 SMD's in it,just be carefull,take your time,a good temprature controlled soldering iron too,a pair of tweezers & maybe 1 of those 'helping hand' thingys off fleebay
    on some of the door switches the smd's are glued aswell so they can be a bit tricky to remove,when you goto replace them try not to hold the soldering iron on the end of the smd for too long.................they dont like a lot of heat,anything else give me or marc sri a PM fella
    Jul 2011
    UK
    Year : 06
    Whs mate the passenger door switch can be tricky as its glued aswel as solderd on. You just got be careful with boards that have plastics on them ie the heater panel has 4 plastic switches touch them with the iron and u will need a new heater
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Marc ive done 50% of mines now but im gettin rear electric windows so im not doing my drivers door yet untill I get the switch for it, I had read some where they were glued, I found out they were glued on the pasenger switch but r they glued on the drivers door as well??
    I would say the heaster panel is the easyest to strip two clips and its off lol
    And to the op its is quite easy, seems daunting at first but once uve done it ure like was that it lol, but the steering wheel controls are hard they are the wee tiny ones I think the headunit is too but ive got a aftermarket in. Just use somthing like a 15 watt iron and use as little heat as possible as it dus them in as I found out :-)
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    Quote Originally Posted by marc vectra sri View Post
    how much was it all marc can do mine for me hahaha
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by rozzer2006 View Post
    No just the passenger one is glued on and the rear ones Heater is the easiest one to do as it does just clip off
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    TBH all the switch clusters have their intricacies. I think the easiest are the clocks. Plenty of room to work, Nice big board and the LED's are nice and big. Hard to get the wrong way round too.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Thats good. Why did they glue them?? Ano thats what im saying I stripped everthing down to see what I needed so I could order them.
    And too answer everyones question I think it would cost for the leds about 30 to 50 quid u need about 60 to 80 mabe more leds depending what ure doing and spares
    My GID screen took what was is mark 34?? So thats a big chunk. And if u were wanting to do ure head unit ive been told its somewhere in the region of 43 so again dependa what u have and what u want to do, u can get new dails too as I have from a wesite called xtuners.com
    Jul 2011
    UK
    Year : 06
    Headunit well the CD 30 think was 24 leds gid is 34 or leds the Speedo is the easiest due to the amount of room was tricky for me to remove them off my mate's bit soon got it took me 15 mins from start of removal to finishing amd refittimg. Also I'd say be careful on drivers switch as there is two plastic switches for the mirrors and the led sits right next to it
  1. Vec C 2.0T LPG Conversion
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2012, 10:13
  2. LED conversion
    By nicj in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2011, 00:51
  3. Led Conversion
    By JonesG in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 20:21
  4. HID conversion
    By spooney in forum Styling
    Last Post: 20th January 2009, 20:20
  5. vxr conversion
    By c9rum in forum Petrol Engine related
    Last Post: 10th January 2009, 20:49
