Thread: Warning Light on start up.
    Lockerbie
    Default Warning Light on start up.
    Whenever I start my 55 plate Vectra C, I get a warning light (car & spanner) on the dash - however, if I switch the engine off and restart it, it doesn't come on.
    Any suggestions as to what this could be?
    newport
    what engine? is it a diesel?
    Lockerbie
    yeah, sorry meant to add that. its the 1.9 cdti engine.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    You will need to get it hooked up and have the stored code read.
    11 Post(s)
    What's the betting it's glowplug related.
    stujrox, does it go out of its own accord after a few mins without you resorting to having to switch the engine off/on again?
    Feb 2011
    Selby
    Or it could be telling you that a service is due.
    11 Post(s)
    Quote Originally Posted by rich r View Post
    Nope, service light is the oilcan/spanner light - if the car is set to ECOService-Flex intervals. Otherwise it'll be the word InSP briefly appearing in the odometer display when you first turn the key.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    as someone else has said its probably glowplug related but you need to get the codes read of the ecu..
    another quick test is too run the glowplug cycle 4 or 5 times before you start the car get the plugs really hot and i bet the spanner light wont come on
  1. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  2. Car/Spanner light on start up????
    By goosey_1976 in forum Engine & Drivetrain
    Last Post: 8th February 2010, 12:00
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
  5. Radiator Warning light on first start of every day
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2007, 11:28
vauxhall astra warning lights spanner before startup
vauxahall vectra warning lights 55 plate
