Results 1 to 2 of 2
Thread: How easy is it to change the engine of a MK4 Astra
    Nov 2010
    Maidstone
    Default How easy is it to change the engine of a MK4 Astra
    Have seen a nice mk4 astra which would be a nice little project, it had the 2.2 lump with a chain jump so i wouldnt bother repairing lump. Whats the possibility of just replacing with a run of the mill 1.8/2.0 lump which are more available?
    Nuts and bolts wise it's straight forward ............... You would however need a donor vehicle to pilfer all the bits from
    i.e. Engine mounts
    gearbox
    engine bay wiring loom
    Ecu
    Ignition barrel
    Keys with transponder
    exhaust system
    possibly radpack with aircon rad
    Possibly front drive shafts as the 2.2 is 5 stud and the small block engines are 4 stud
    maybe also the gearstick with linkage
    But it is all just unbolt and bolt on stuff
  1. Astra VXR gearknob, easy to fit?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2012, 11:22
  2. How easy is it to change the fuel filter?
    By PeterVV in forum Petrol Engine related
    Last Post: 29th June 2009, 21:26
  3. Is there an easy way to change the glowplugs??
    By bennettboy in forum Engine & Drivetrain
    Last Post: 13th October 2008, 14:20
