Results 1 to 10 of 23
Thread: Spark Plugs - when to change?
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default Spark Plugs - when to change?
    Can anyone advise on a couple of questions ?
    1) When is the recommended mileage for changing spark plugs on the petrol Vectra's? (Mine is a 2.2 Direct)
    2) What are the best options? NGK,Bosch ? Iridium,standard?
    John
    Regular Member Robward27's Avatar
    Witham
    Been told @ 40,000 mile service.
    Regular Member simac's Avatar
    Wirral
    For my 1.8 it's 4 years or 80K miles i.e. 2nd major service
    Melbourne, Australia
    Holden's owner's manual recommends changing at 60,000 km/4 years for both Z22SE (3.2l V6) and Z32SE (2.2l 4) petrol engines
    Apr 2006
    Inverclyde
    That's what my manual says,but 80k for a set of plugs?? Is this realistic?.My car is almost 3 years old and at 35k.Any benefits of changing them now? Standard or aftermarket?
    John
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    I've got the 2.2 sri,Am i going mad here?
    Dont we have a coil pack?
    Pretty sure i don't have plugs on mine
    Apr 2006
    Inverclyde
    You're probably right mate. I skipped through the manual after my 40k service to see what was/wasn't done and I was sure I came across something about 80k.I am only posting now as I keep forgeting to ask the question.If you are correct,does this mean "maintenance free" i.e. only investigate when something goes wrong oor is there a check/interval for this?
    John
    Apr 2006
    At the Garage
    Yep that's it mate,its somet looked at during future services i believe.
    If any fault does develop you'd now about it,such as unreliable starting/ power output etc,and a code read would help in spotting it.
    Anyone with greater knowledge correct me if i'm wrong.....
    Wirral
    Quote Originally Posted by sparky71a View Post
    Every petrol engine has sparkplugs guys, the coil pack is used instead of HT leads, you have a coil per cylinder rather than one coil doing the whole job
    Mine is 3.5 years old with 50k miles on it on the same plugs. It runs fine, my only concern would be getting the things out after being in so long
    Jan 2006
    Hornchurch
    I would change them every 10k as they are only 99p at trade from vauxhall
    the cars runs better with new plugs i found also a few more bhp an better mpg to the old plugs
  1. How often do you change the spark plugs???
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 12:36
  2. How To Change Spark Plugs On 3.2 V6
    By tommyk999 in forum General Chat
    Last Post: 15th February 2008, 14:39
  3. How on earth do you change the spark plugs on the 3.2 ???
    By muffking in forum Engine & Drivetrain
    Last Post: 17th February 2007, 15:06
vectra c how often change spark plugs
how to change spark plugs vectra c
often change spark plugs vectra 1.8
