Thread: Passenger Window Switch
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Default Passenger Window Switch
    I want to check my passenger window switch as the down button doesn't always work.
    Looking at my Haynes manual, it looks like the drivers side just pops off with a screwdriver, but looks like you have to remove the door card for the passenger side. Is that right??
    Carl
    Sent from my Samsung Galaxy SII using Forum Runner
    newport
    passenger side just pops out with a screwdriver aswell, no need to remove door card, open the switch up and clean the gold contacts on the circuit board and the rubber sheet, i used nail varnish remover (not mine, the mrs lol), then put it all back together and job done, 9 times out of 10 that fixes the intermitant switch problem
    Engine : 1.9 CDTi
    I think there is a guide in the HOW2 section
    newport
    i made a how2 guide but over on vvoc
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Had same prob with mine wen i bought it, used them as a bargain tool and got some money off. Got home popped em out cleaned and been fine ever since. Not hard to do at all mate.
    milton keynes
    There is a how to guide , but dont use sandpaper as suggested , just use an eraser
    May 2011
    Well I just took it off, give it a blow and it seems fine. If it happens again I will clean the connections like suggested.
    Carl
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Quote Originally Posted by Carl83 View Post
    Carl
    glad you have sorted it out more info here
    http://www.vectra-c.com/forum/showth...-Window-Switch
  1. passenger window switch
    By brod999 in forum General Chat
    Last Post: 28th December 2015, 22:54
  2. passenger window switch
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2010, 22:22
vectra c gsi passenger window switch not lighting up
