Results 1 to 2 of 2
Thread: blanked egr but swirl bar looking oily again
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default blanked egr but swirl bar looking oily again
    I blanked off my egr (on the exhaust manifold side)about 2 years ago after having a new inlet manifold.
    But i have noticed that there is quite alot of oil and crap build uo around the swirl bar/pots again. is this supposed to happen?
    i thought blanking eliminated it?
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Quote Originally Posted by monty2000 View Post
    Blanking the EGR will only stop the soot, but this mixing with the oil is what causes all the issues.
    The oil is most likely from your engine breather setup, it's not very good at separating the oil mist on these engines and gets into the inlet pipework. You may find that your throttle body fills up with oil and packs up so it's worth stripping this down to clean it.
    The oil in the inlet manifold shouldn't actually cause any problems and may actually help to lubricate the swirl flaps where they come through the manifold, but I know what you mean about it being a mess.
    Some members have fitted oil catch tanks to reduce this so do a search for those threads.
    If the oil is excessive as in blue smoke from the exhaust sort of quantities, then your turbo seals are suspect and if this is the case, you really need to get the turbo looked at ASAP before the engine runs away (runs on engine oil).
  1. Oily air filter!
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 29th December 2011, 12:47
  2. Oily smell inside cabin when stopping on lights/junctions/roundabouts
    By crism in forum Vectra C / Signum Troubleshooting
    Last Post: 19th July 2011, 07:46
  3. EGR blanked 2.0 DTI
    By superfox233 in forum Engine & Drivetrain
    Last Post: 17th February 2011, 15:31
  4. oily air intake
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 14th January 2010, 04:09
  5. Oily stuff!
    By SWIPER in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2009, 14:55
