Results 1 to 10 of 29
Thread: Z19DT EGR Blanking Help....Please
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Default Z19DT EGR Blanking Help....Please
    Well... Today i blanked my EGR off.......
    I also cleaned that lil boost sensor thing on rad, and cleaned boost pressure sensor on back of inlet manifold...
    Now.. it rev's alot more freely... but slugish when going from idle to around 2.5 then picks up were as before it was other way round?
    Any idea why this is.???? tbh.. i preferred as it was before lol. Thanks
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Vectra Adz View Post
    Just to confirm, now you have blanked your EGR, it has lost low down power before 2.5K?
    Is everything tightened up properly, assume you now have the spanner/emissions light on now?
    Is it a full blank? Looking at your other posts, it seems your EGR might be faulty, do you still get the soot on the outside of the expansion bottle?
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    I put the blanking plate on the inlet manifold??? Im assuming thats where i wanted it to go ? I wernt 100% as im not really a mechanic lol....
    Everything is defo tightened up yes. And EML is on and its saying EGR Permanent...
    And not had a chance to see if its still leaking, to which is dont sound like it is any more...
    I also put airbox back on today as well....
    Lancashire
    Trim : XP1
    Mileage : 66000
    Is this a 150 or 120?
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Sorry its 120. Thanks
    Lancashire
    Trim : XP1
    Mileage : 66000
    Was it a full blank, or one with a hole?
    It sounds like the EGR may not be sealing properly, you could fit another blank to the exhaust inlet side to rule that out - seems odd that its made it more sluggish.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Yes it was a full blank yes. Will that do anything then by blocking that other bit of as well?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Normally when an EGR seals up ok, when its blanked the manifold gets no EGR gasses and the exhaust fed has nowhere to go and basically ends up only going out of the exhaust, if your EGR doesn't seal then blanking the exhaust side could still mean the manifold has (in essence an air leak) or blanking the manifold side would mean exhaust gasses are leaking - blanking both stops them.
    I'll be honest, I am led to this based on your other post saying that something had been blowing crud onto your expansion bottle (where the EGR is), so may not be the case.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    I will try that and see what happens then, ive noticed on my journey home its gone from 40.9 avg MPG to 39.0mpg.... drove no different.. but it never really moves from 40mph tbh.. and when you rev it on the spot it feels juddery as such... i just want it to work lol...
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    help please
  1. Z19DT EGR Blanking Help....
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 16th January 2013, 20:30
  2. Z19DT EML Help...
    Last Post: 19th November 2012, 23:10
  3. Z19DT OP-COM readout
    By Astra H in forum Engine & Drivetrain
    Last Post: 30th April 2011, 13:28
  4. Z19DT vacuum.what is this?
    By tox in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 15:50
  5. New 1.9CDTI DMF Z19DT - £100
    By danBoy in forum Parts for sale
    Last Post: 7th January 2009, 19:39
z19dt egr blanking
blanking egr on z19dt engine
