Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: thermostat change
    Regular Member vectra-man's Avatar
    Dec 2012
    basildon
    Vehicle : signum 2.2
    Default thermostat change
    Hi I have just changed the thermostat + housing on the vec genuine vauxhall parts, done everything as on the how2 but whilst idling the air is at best warm but whilst driving is lovely and hot. I have had the cap of for around 45 min with heater on and still no different.
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    are you getting fluid returning to the header tank?
    Dec 2012
    basildon
    hi vmb2722 yes water is returning to the header tank.
    May 2012
    Trim : Exclusiv
    have you undone the bleedscrew on the coolant rail at the front of the engine?
    May 2012
    Trim : Exclusiv
    try removing the feed pipe to the heater matrix untill water runs through
    Dec 2012
    basildon
    Quote Originally Posted by vmb2722 View Post
    I got told the 1.8 does not have a bleed screw. I will go outside and check.
    May 2012
    Trim : Exclusiv
    Quote Originally Posted by vectra-man View Post
    yeah my bad i was thinking of my car
    Dec 2012
    basildon
    What pipe is the feed pipe left or right looking at it, whilst i was bleeding it earlier all pipes got hot other the the left pipe coming/goin to the matrix
    May 2012
    Trim : Exclusiv
    the one thats cold should be the return, take that off and see if you get coolant out the matrix
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Are you sure that the engine is fully up to temperature when it was ticking over - mine has been acting a bit strange with these colder outside temperatures (-5) ie taking a lot longer to warm up and no reading on the gauge for a long time after starting but warm air in the car. You could also consider that the new thermostat is faulty - it has been known.
  1. thermostat change
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 12:52
  2. thermostat change
    By smartalec0310 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 17:54
  3. thermostat change
    By marc vectra sri in forum Troubleshooting
    Last Post: 27th October 2012, 00:27
  4. Do i change my thermostat?
    By beggsy in forum Engine & Drivetrain
    Last Post: 26th May 2012, 10:59
  5. How to change a thermostat 2.2
    By vx sri in forum Engine & Drivetrain
    Last Post: 22nd March 2011, 22:05
