Thread: Signum cutting out when using wipers!
    Dec 2012
    sunderland
    Default Signum cutting out when using wipers!
    Hi, I recently bought a 2007 Signum 1.9 cdti. It wasn't raining the day i bought it so didn't use wipers, never used it due to bad weather. Started it up today turned on wipers and engine cut out, every time i use wipers engine cuts out and power steering light comes on for a few seconds.
    Any ideas?
    Plugged opcom in and these are the fault codes.
    Any help much appreciated.
    OP-COM - CAN Communication Window> 2007 (7)|Vectra-C / Signum|Body|BCM (Body Control Module)
    Read Info...
    Identifier: 0x0209
    VIN:
    Part Number:13193590
    Software version number: D02D11 49041605
    Hardware key number: ˙˙˙˙˙˙˙˙˙˙
    System description: TEMIC04
    Variant programming: 0x20202020202020303031353235333835
    Alpha code: NF
    Manufacturing date: 000600080103
    Code Index and version:
    Total number of fault codes: 1
    B2930 - Anti Theft Warning System Disable Switch Circuit Open or High Voltage
    (05) - Present
    OP-COM - CAN Communication Window> 2007 (7)|Vectra-C / Signum|Body|CIM (Steering Column Module)
    Read Info...
    Identifier: 0x0014
    VIN:
    Part Number:13204147
    Software version number: 12244872_
    Hardware key number: *89HFTE
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 060718
    Code Index and version: 008 02
    Total number of fault codes: 2
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (00) - Not present
    U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
    (00) - Not present
    OP-COM - CAN Communication Window> 2007 (7)|Vectra-C / Signum|Body|Immobilizer
    Read Info...
    Identifier: 0x0014
    VIN:
    Alpha code:
    (00) - Not present
    (00) - Not present
    OP-COM - CAN Communication Window> 2007 (7)|Vectra-C / Signum|Body|Instrument
    Read Info...
    Identifier: 0x1203
    VIN:
    Part Number:13193068
    Software version number: 3.40 10/05
    Hardware key number: 0000000000
    System description: VDO 0400
    Alpha code: QH
    Manufacturing date: 060814
    Code Index and version: 005 05
    (7F) - Not present
    (7F) - Not present
    OP-COM - CAN Communication Window> 2007 (7)|Vectra-C / Signum|Chassis|ABS/TC/ESP
    Read Info...
    Identifier: 0x6003
    Hardware number:0
    System name: ABS 430 NG
    Part Number:12773671
    Software version number: 00C2E92D
    Alpha code: BS
    Software Freeze Date: 00465638
    ECU variant coding: 0x00001514
    (00) - Not present
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Looks like a wiring fault.
    Check body earth's and battery terminals and fuses.
    Check the wiring from the ecu to the power steering pump and abs unit make sure its not chaffing on anything and its securely plugged in and free from corrosion.
    Ask one of the moderators to erase your vin number from the post also.(you never know)
    Good luck.
    Dec 2012
    sunderland
    Thanks! Fuses are ok but i'll check wiring tomorrow.
    Cheers John.
    Dec 2012
    sunderland
    Car now fixed it was the uec causing the problem. Fitted a secondhand one from ebay, now all working properly.
    Thanks for your help guys cheers
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Was the car jet washed washed before you bought it?
    seen problems on UEC circuit board when water gets in after being power washed. Causes all sorts of intermittent problems.
    drying out and cleaning with contact cleaner sorts problem
    whoops just seen date and that you've sorted it.
    good effort
    May 2011
    South London
    Quote Originally Posted by jbz40 View Post
    Its probably the UEC
    Ah Critch beat me to it......
    Oh the OP beat me to it......
  1. Signum 3.0 cdti, cutting out at speed
    By Wal2705 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 18:08
  2. Signum 2.2 DTi cutting out/ loss of power
    By muzmayhem in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 15:14
  3. Signum rear bumper lower trim cutting question
    By stoneshed in forum Styling
    Last Post: 27th January 2010, 08:23
  4. Signum Front Wipers Fault
    By TONYWING in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2008, 14:46
2007 vauxhall vectra has fault with wiring for wipers causing car to cut out
opel corsa 09 cuts out wen wipers on
