View Poll Results: Which Would You Have In The Event Of A Flat / Damaged Tyre ?
Voters
87. You may not vote on this poll
  • Space Saver .
    23 26.44%
  • Sealant Repair Kit Can .
    4 4.60%
  • Full Size Spare .
    68 78.16%
  • Break Down Cover = A.A / R.A.C. etc
    11 12.64%
  • Tow Truck / Carrier
    1 1.15%
  • Run Flat Tyres .
    0 0%
  • A Flying Car = L.O.L.
    4 4.60%
  • Other Option = Please state in a reply .
    1 1.15%
Multiple Choice Poll.
Results 1 to 10 of 25
Thread: S/Saver Vs Sealant Vs Full Size Vs Other
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    Default S/Saver Vs Sealant Vs Full Size Vs Other
    What would you choose to have in your boot should you need to to fix a flat / damaged tyre ?
    1) Space saver
    2) Sealant temp repair kit
    3) Full size spare
    4) Other ( whatever it may be ,,,, A.A. / R.A.C. / Tow Truck etc ) ...
    Yes this would not fit in your boot , but a break down card in the glove box would ...... L.O.L.
    5) Run Flat Tyres .
    Just been reading this on What Car . Com .
    http://www.whatcar.com/car-news/what...o-spare/227298
    Q: Can you tell me why the Vauxhall Zafira is being sold without a spare wheel as standard?
    Surely this is against the law?
    Roger Riggott, via e-mail
    A: Increasing numbers of cars are being sold without a spare wheel, thus saving space and weight in the car.
    There is no legal requirement to carry a spare wheel - the law only says that if you do carry one, it must comply with the laws on tyre condition and tread-depth in order to pass an MoT test.
    However, it is advisable to carry a spare wheel; it may also be a condition of your breakdown cover.
    One solution is a space-saver tyre, which is narrower and lighter than a standard wheel.
    Another is a can of sealant that temporarily inflates the wheel and seals the puncture - and that's the solution Vauxhall uses for the Zafira.
    Both these systems are temporary fixes and are designed simply to get you home or to a tyre fitter.
    11 Post(s)
    Quote Originally Posted by HITFACTORY1403 View Post
    Wrong advice given by whatcar. The spare isn't part of the MOT test as such It only applies to tyres fitted to the road wheels only. However the vehicle presenter should be informed when it is noticed that there is a defective tyre on a spare wheel.
    http://www.motuk.co.uk/manual_410.htm
    If it was part of the MOT test, then any car with a space saver would fail as it's a different nominal size or aspect ratio to any of the other tyres.
    Space saver wouldn't bother me if I only had a short journey to do, otherwise a full sized spare.
    No way would I want just a can of goo.
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    153 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Not having access to the spare wheel well (LPG Conversion) I would not feel happy travelling without a spare, and, the space saver offers me the least boot space intrusion.
    Having said that, I also carry an aerosol puncture repair inflator because there are circumstances where I wouldn't feel too happy about changing a wheel (motorways - especially at night, dark country roads... you get the picture).
    The last time I called the AA to report a puncture (18 months ago) at 1am on a busy country lane, they asked if I had a spare wheel, and at that time I only had an emergency inflator...... I was advised that I would be charged for the callout if I wished to proceed...... No thank you was my reply.
    Really, if you can carry a "spare" then I would advise it and it doesn't "have" to be a full sized wheel replacement,after all, you are going to get the puncture/tyre dealt with, so what does it matter if you use a space saver in the meantime ?
    Mar 2011
    I must point out that What Car article is dated 2007 , but i guess most of the information still stands up .
    Regarding the Puncture Repair Kit Can of Goo .
    It's no good if you have ripped your tyre a big hole in it , i guess .
    Also ......... If it is repairable .............. What garage will want to repair a wheel full of gunk ?
    Because i guess it needs scooped out , incase you need to temp fix your tyre again in the future .
    If you rip your tyre at a time when no tyre dealers are open , what do you do without a spare wheel and you don't have break down cover either .
    Yeppp ...... Spare wheel ( Full or S / Saver ) for me ..... All the way .
    But i forgot my Poll was multiple choice and only voted for Full Size .... Silly Me .
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Can of sealant is no use if you have a blow out. I have run on the space saver(on the rear) and was very surprised at how compliant it was. I think the days of full size spare tires are a thing of the past due to cost and weight savings.
    Dec 2011
    Seaham
    I would always prefer a full sized spare. however can see the practicalitites of a space saver. Cans of foam and compressors are a big NO for me.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Space saver is perfectly fine for me, wouldn't like a snowie/tyre in the boot, and the can of foam stuff isn't practical for all eventualities.
    Feb 2011
    Selby
    I've driven in snow in the Peak District on a space saver (admittedly on my old Subaru Legacy), and was also surprised at the way handling wasn't anywhere near as affected as I thought it might be. Yes, I was sticking to about 45mph (max speed on space saver is 50mph) which probably helped, but I certainly had no issues driving from Bakewell to Chesterfield where I got the punctured tyre replaced.
    As I've got LPG, space saver in the boot is perfectly sufficient for me. Full sized would take up too much room. I carry a can of Tyre-Weld as well just in case I get two punctures
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Space saver for me. Reduces the weight and I can live with driving slowly home. I wouldn't ever want runflats or a sealer kit or to have nothing.
    Mar 2011
    Not for me , but some like the sealant repair kit ....
    http://www.honestjohn.co.uk/news/par...2011-08/slime/
    New Tyre Sealant Fixes Punctures Without Destroying Tyres
    Britain's appalling damaged roads mean thereís even more chance than ever of getting a flat tyre, and with dark, wet nights once again fast approaching the last thing you need is to be stuck at the side of a road waiting for breakdown assistance to arrive.
    One alternative to runflat tyres is some form of tyre sealant, either in the tyre permanently, or applied when you get a minor puncture (obviously. no sealant can fix a shredded tyre).
    The problem with many of these is they destroy the carcasse of the tyre so the puncture cannot be permanently repaired. The answer is a non flammable water based tyre sealent from ther USA called Slime.
    Used by the AA in its roadside repair vehicles, Slimeís range of tyre sealant products are quick and easy
    to use and provide total reassurance and convenience for regular road users, who rely on their car every
    day, as well as families and drivers who arenít able to change a flat tyre themselves! All you have to do is
    follow the simple, on-pack instructions:
    Quick Spair, RRP £9.99 (12oz) - £11.99 (16oz) - an emergency tyre repair product that seals the leak and temporarily re-inflates the tyre in one handy can. Plus, itís the only non-flammable, water soluble tyre repair product on the market, so itís safe to carry in your car and can be cleaned out of the tyre so that it can be professionally repaired, rather than replaced, if needs be:
    1. Rotate puncture to 6 oíclock position
    2. Shake can (donít remove puncturing object)
    3. Attach nozzle to valve
    4. Press Green Button
    5. Inflate until can is empty and rim is off the ground
    6. Drive slowly for 2-4 miles to distribute sealant, and away you go!
    Slime Tyre Sealant, an environmentally friendly, non-toxic, non-hazardous, water-based sealant which
    contains shredded, re-cycled tyres and, in conjunction with a portable air compressor, can be used for
    semi-permanent repair of punctures up to 6mm. The sealant remains liquid in the tyre and is safe for use at normal driving speeds. It can also be cleaned out of the tyre so that it can be professionally repaired. Whatís more, once youíve re-inflated your tyre you can continue with your journey in confidence and get your tyre checked professionally at a more convenient time. RRP £8.99 (8oz) - £12.99 (16oz):
    1. Position valve core 8-4 oíclock
    2. Remove puncture object (if possible)
    3. Slowly remove valve core
    4. Allow tyre to fully deflate
    5. Attach hose and install sealant
    6. Replace valve core
    7. Inflate tyre
    8. Drive. Stop. Verify seal and check pressure.
    For a complete, semi-permanent repair solution in one pack you can also purchase a Slime Smart Spair Kit (RRP £29.99 (16oz)), an all-round emergency tyre repair kit, including a 16oz Slime tyre sealant and high-
    power air compressor. Christmas Gift tip: an ideal Ďpeace of mindí stocking filler for people who regularly take long journeys.
    Available from independent retailers nationwide, you can find your nearest stockist by visiting www.slime.com
    to find out more about Slime products.
  1. What size wheel will fit in boot to replace space saver?
    By Ace1981 in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2012, 19:59
  2. 19" Snowies - Changing Tyre Size (& Getting Rid of Space Saver)
    By DanR in forum Suspension, Wheels & Brakes
    Last Post: 12th December 2010, 00:01
  3. Full size Spare wheel??
    By JamesGTB in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2009, 19:41
  4. Full size spare
    By rumour6 in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2008, 09:22
