Thread: abs light on
    leeds
    Default abs light on
    hi i have a vectra c 2005 abs light on had it tested found fault on nearside front wheel . brought car home and checked out , found open circuit in one of the sockets,repaired, question light still on do i have to go back to garage again and pay or is there a way to get light to go out, any advice would be very welcome thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Fault light should clear after so many engine starts if the fault has gone.
    It can be cleared with a code reader too
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    If you have open circuit in socket light should go out as soon as repaired correctly
    scotland
    check for continuity in short (removable harness) between white 2 pin plug and other end attached at strut.
    if ok it could be the hub needs replaced .
    more than likely its the 2 pin plug thats corroded though !
    leeds
    thanks did check continuity from above plug on wheel arch to sensor and repaired open circuit,replaced hub 18 mouths ago ,mileage about 8000 (use motorbike and wife,s car) would disconnecting battery and reconnecting do any thing, when i had it at the garage they reset it but when i drove it away it came on as they said it would as the fault had not been repaired.
    scotland
    if its an 'open circuit' then it will always show .
    if you know someone wi a vec swap the short harness over , then you will know if its a hub or not ?
    failing that buy a cheap ABS wire from ebay etc , then work from there .
    scotland
    leeds
    had a read thanks gsxrster i think the wireing is ok now,looked at fault code scanners on ebay and some say will not reset abs confused!
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    There used to be a 'calibration' procedure you could do with Omegas that may (or may not) be of help - basically you go for a drive, get over 60MPH and then clutch down and let the car slow on it's own to below 50MPH, then clutch back up and speed up and do it all again twice more.
    The idea is that it lets the relevent ECU reset the relationships between all the wheelspeeds.
    However. first things first, sort your wires.
    leeds
    thanks handyandy well try what you said,when iv dug it out,roll on summer
    By Shadrack in forum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
