Results 1 to 10 of 13
Thread: Signum 2.0t performance question
    Aug 2010
    Cumbria
    Default Signum 2.0t performance question
    Hi,
    Just looking for a bit of advice. Had remap done a couple of years ago by Torquing BHP and after replacing a couple of sensors the car ran fantastic. Around six months ago I started getting a slight blow from exhaust flexi connector and performance really suffered, but couldn't afford a new exhaust system as mechanic said it was all about knackered and so put up with it until I saved up the cash. Anyway car had a service a couple of weeks ago and showed the rear lambda sensor was iffy, so this was replaced. The car now runs a hell of a lot better, but not as good as it originally did. I have covered a couple of hundred miles since so I presume the ECU will have the correct settings now. So my point is will a slight blow in the exhaust cause much of an issue? (I will be replacing the exhaust next week BTW). I have also heard things about disconnecting the ECU for it to reset itself, don't know how true this is though? Sorry for long winded explanation and thanks in advance.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    disconnect the battery for half hour, thats all I do...
    I have the facility to reload my map any time though as mine is on a handheld PPC module...
    Aug 2010
    Cumbria
    Thanks, what will disconnecting the battery do to the ECU? Not overly clued up on the subject....
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    it will clear any stored codes as such and default the ECU to mapped settings.. I do mine every other month as the ECU adapts to driving styles, if I am driving around on an economy run for a months for some reason then the ECU learns this.. When i disconnect the battery all sensors and ECU default and reset, hey presto instant animal again...
    Aug 2010
    Cumbria
    Brill thank you, will give it a try tomorrow and see how I get on.
    Aug 2010
    Cumbria
    Just out of interest, do you think the slight blowing on the exhaust will make much difference?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Not really, the turbo provides the back pressure but you have a lambda sensor after the flexi. As as advised if the ecu thinks something is out of kilter it will adapt.. Always best to fix exhaust leaks enyway. Flexi sections are cheap enough to replace. When you get a chance you can replace the remainder of the exhaust with a stainless system.
    Aug 2010
    Cumbria
    Many thanks to Caveman Nige, did the ECU reset and the car drives like it use you, a really big improvement.... BUT when under load in fourth gear onwards it gets to round about 3-3500prm and I loose all boost, like I have hit a brick wall! Lower gears are fine and if I don't floor it in higher gears its OK, just seems when the turbo is under load such as uphill or if your sending it on a bit. No engine management light and if I turn ignition off and back on its fine again, until fourth gear. Anybody have any ideas??? Thanks
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    its sounds like you have the Garrett turbo fitted in yours, I am tempted to say without any other info to work off that your wastegate diaphragm or its spring is worn out..
    Aug 2010
    Cumbria
    OK, is this much of a job to fix Nige?
  1. MAS Performance question
    By s11mhk in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2012, 10:53
  2. 2.2 Performance Question
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2011, 17:45
  3. Sluggish Performance with Signum 1.9 CDTI
    By flensberg in forum Engine & Drivetrain
    Last Post: 1st May 2010, 08:59
  4. Performance box Measure your cars performance..
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2007, 18:09
  5. Vectra/Signum 2.0T induction kits \ performance panel filters
    By joules2.0t in forum Petrol Engine related
    Last Post: 5th March 2006, 10:04
