Results 1 to 10 of 17
Thread: 1.9 8v problem
    Regular Member rioni's Avatar
    london
    Default 1.9 8v problem
    Hi to all , i have problem with my vectra, start's fine in morning but dosent rev's only 1000-1200 rpm and stals please any help , no error
    cheers
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    how long before it stalls?
    Carnoustie
    I had this with the 16 valve it was a stuck egr valve!
    Ronnie
    london
    1-2 minutes then stalls i also try to unpluged the egr but same alot of blue white smoke turbin is whinig a little cheers thanks
    Carnoustie
    if the egr is stuck unplugging will not work
    london
    Hey this is a video of symptoms, http://www.youtube.com/watch?v=btVo0NEEYns
    london
    Here is a second video trying to accelerate a lot of smoke
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Turbo
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Bit inconsistent, you say it wont rev over 1200rpm then vid shows it at 2500rpm
    and cant hear the engine properly at all so those vids and fault description are useless to be honest.
    Take it for a Tech 2 session
    If your near me pop it over I'll have a look .
    May 2011
    South London
    BTW check the cat hasn't collapsed first causing a blocked exhaust
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
