Results 1 to 10 of 20
Thread: My Vectra and traction control in the snow
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default My Vectra and traction control in the snow
    I must admit my Vectra is quality in this snow the traction control really helps, plant the right foot and the revs stay at 2000 rpm and just pulls me up the hill, I did have suspicions that I had tc had when I first had it I spun the wheels pulling out of a side road and the light on the dash flickered, now snow is here I got to test it properly, I have also fitted the tc switch but I think I need to tech 2 it so I can have the option of switching it on or off
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    If the wiring is there for the switch, it doesn't need Tech2'ing
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I have the switch and it lights up with dash etc, I also know I have tc has I have tested it but I'm unable to use the switch to turn it off so how do I solve this issue
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Siggie is nice and planted. Autobox snow mode sticks it in 4th but tbh just taking it easy makes it fine.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by pipamish View Post
    You might be lucky and just need to add the extra two wires that are missing from the loom in order for it to work. Did it on mine and it works perfectly now. Only seems to work on the higher end petrol motors, but the 2.0T is one of them it does work on
    Can't remember which wires exactly, I'd have to check, but it's one wire from the ABS module to the main connector in the passenger side kick panel and one from that connector to earth. A quick search of the forums should find the details.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Found it:
    Pin 3 on the ABS module to pin 26 on the X1 plug
    Pin 25 on the X1 plug to earth
    Note: both pin 25 and 26 should already have wiring in them, you just tap the new wires into those.
    Regular Member Vectra Dan SRi's Avatar
    Dec 2012
    Nottingham
    mine has no traction control which i thought was a little strange considering the year of her as my astra on a 52 plate had traction control?..
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    i just added the switch , and it worked !
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    mine didnt have TC but had the wiring there so i just added it along with ESP
    Regular Member mike.'s Avatar
    Oct 2012
    peterborough
    Trim : SRi NAV
    Engine : 1.9 CDTi 120
    i fitted a switch to mine and it didnt work.
    the will the wiring trick work on my 55 plate facelift?
  1. traction control in snow
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2010, 18:09
  2. Traction Control and/or 4x4 (snow/ice)
    By Birchy63 in forum The 'Off Topic' room
    Last Post: 21st December 2009, 15:10
  3. vectra b traction control
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2009, 21:04
  4. Traction Control in Snow
    By Ridgerider in forum Engine & Drivetrain
    Last Post: 13th February 2007, 14:54
  5. vectra c turbo traction control
    By B16VJB in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2006, 13:30
