Thread: D900 Any OBD2 EOBD CAN BUS Car Engine Fault Code Reader
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Default D900 Any OBD2 EOBD CAN BUS Car Engine Fault Code Reader
    hi guys i have another fault code scanner for sale only used once on my honda civic but wont work as it needed a manufactur specific scanner to work (enventually found one that works lol)any way im looking for £22 inc postage ono . here what it can do.
    D900 OBD2/ EOBD CAN-BUS Fault code Diagnostic tool
    package come with : D900 Code Reader , OBD2 Cable , Manual CD ,
    plus free CD software with over 7000 DTC code finder, just type the code it will give code full definitions
    Plus 160 common fault codes explain in detail & Possible Solutions
    Inc : What does the code mean in detail , Symptoms , how the fault Causes and Possible Solutions
    The latest 2012 version .It's compatible for the protocols: CAN, KWP 2000, ISO 9141-2, PWM, VPW.
    Specifications:
    Easy to use with one plug-in
    Works with all cars that are all OBDII compliant (including the CAN, J1850 PWM, J1850 VPW, ISO9141 and KWP2000 protocols)
    On screen to Read hard (memory) / pending (intermittent) and historic codes and show definitions.
    Erase codes and reset MIL
    View live data stream
    View freeze frame data
    Determines the malfunction indicator lamp (MIL) status
    I/M monitor readiness test
    Vehicle Information (on vehicles that support Mode 9)
    Record and playback
    Highly reliable and accurate
    item only works with engine , not work with airbag abs or transmissions.
    Display: backlight 128 x 64 pixel display with contrast adjustment easy-to-read screen and also saves up to 15 scans
    for later viewing.
    Operating temperature: 0-50 C (-32 to 122F)
    External power: powered directly by vehicle
    Trim : vxr
    Mileage : 31000
    Evening bump
    Trim : vxr
    Mileage : 31000
    Monday bump
    Trim : vxr
    Mileage : 31000
    Another bump before eBay £20 inc postage ?
    Trim : vxr
    Mileage : 31000
    Now sold
  1. OBD2 Code Reader
    By John Bishop in forum General Motoring Chat
    Last Post: 28th June 2012, 17:34
  2. For Sale: Autel Maxiscan MS509 OBDII/EOBD Code Reader
    By Mads in forum General items for sale
    Last Post: 12th December 2011, 20:19
  3. Car Diagnostic Code Reader / Scanner OBD2 CAN U581 2009
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 21:27
  4. VAUXHALL VECTRA C compatible OBD2 FAULT CODE READER
    By big rich in forum Parts for sale
    Last Post: 16th February 2009, 02:25
OBDII Engine Fault Trouble Code Read
d900 obd2 work with vauxhall
