Thread: Help. vectra c clutch problem
    Jan 2013
    warrington
    Default Help. vectra c clutch problem
    Hi
    I recently had the clutch and dmf replaced along with the slave cylinder
    The problem i have now is that i dont get the same biting point, I mean that most of the time i depress the pedal the biting point is in a different place. The pedal also sticks sometimes and also sometimes is very light to press
    I replaced the master cylinder yesterday bled the whole system and its still the same ???
    Had it back at the garage and they claim that when they took it out on a test run everything was fine.
    Any help on this matter would be grateful before i go back to the garage kicking off
    Thanks John
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    they can claim what they like.. take it back and say you want it looking at....
    IF they don't its time to name and shame, start with you local trading standard and local newspapers... but give them a chance to sort it first..
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    we had a similar problem with a 2.0 dti vectra C , apparently the slave cylinder was a cheap one & they don't work as they should .
    lincolnshire
    take it back , it should have a slightly lower biting point but thats all
    Jan 2013
    warrington
    Going back on Wednesday
    Dont want to be stuck with another bill , if its something i can do myself
    Hope its something they have done
    Feb 2011
    Oxon
    I had the same problem after clutch/dmf/csc change. Took it back several times but they said it was fine on the test drives. Eventually they changed the master cylinder (at my expense) but still the clutch would disappear to the floor. It seems to only happen now under hard acceleration and even then only rarely. I don't know if its something to do with sharing the hydraulic fluid with the braking system(?) but I'm sick of going back and forwards to the garage to be told there's nothing wrong with it.
    Reading other threads on here it seems to be a common problem but still remains a mystery as to what causes it.
    Dec 2011
    Seaham
    If it isnt right, take it back for them to sort it out.
    Otherwise they could use the same excuse for doing any job? Just imagine if it was your brakes, well they worked when we test drove the car, really can you therefore explain why they didnt work when I rammed someone else up the backside??
    Jan 2013
    warrington
    All sorted now
    dmf couldn't believe it,total failure on a new papart this must of failed on there test drive when it was first fitted because it has never drove so well
    thanks again for all your responses
  1. clutch problem?
    By tjr2011 in forum Engine & Drivetrain
    Last Post: 20th March 2012, 18:30
  2. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  3. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  4. Not Vectra but Corsa clutch problem.
    By gtr1000 in forum The 'Off Topic' room
    Last Post: 6th May 2010, 20:30
  5. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
