Results 1 to 10 of 18
Thread: Rear electric window help
    Full Member RBH's Avatar
    Jan 2008
    North Lanarkshire
    85 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : 1.8 vvt
    Mileage : 73,166
    Default Rear electric window help
    Ive just sourced a 2004 design edition hatchback thats complete and has the electric window set up in the rear doors.
    i know i would need to take the looms from the rear doors, rear door switches and window motors.
    a few questions tho............
    1 - will these fit my 2008?
    2 - is there any way i can check if my car has the electrics for the set up in the pillar?
    3 - does it need to be tech 2'd?
    4 - is there anything else i'd need from the donor car?
    or is it not work the hassle doing this mod?
    cheers guys
    rab...............
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes they will fit and you will need the drivers door switch as well but you won't have the body wiring in your car it will need to be added which can be done but it takes a few hours to do. You could double check by removing the plug between the rear door and the car to see if you have 2 large pins at the top side by side on the part going into the car but being a 2008 it is not likely and yes a tech 2 session to enable them is required also grab a couple of plastic covers from the side of the centre consol as they fit over the window winder hole in your door card.
    Jan 2008
    North Lanarkshire
    85 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : 1.8 vvt
    Mileage : 73,166
    thanks paul.
    if the plugs dont have the wiring......how much off this do i need?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    A couple of wires from the rec for the power feeds and 5 wires or so between the doors and the x plugs in the front footwells for the switch controls and illumination. .
    Aug 2012
    worcester
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3.2 v6
    sorry for butting in but ive done this went for tech 2 they said they couldnt do it as switch must be faulty, now i tried them on car i stripped for bits so know they worked.
    my two year old daughter has found one rear window will open an close from rear window switch they wont work from front one, not too worried about that, ive tried swapping switches side to side so its not the switch i cant find a live on the one not working coud i find one from anywhere else??? was thinking of swapping loom around trying that i have live at the two big pins..... any ideas thanks
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Not correctly wired up, It can be tech 2'd, I borrowed a tech 2 for 5 minutes and programmed my car when I did a rear electric window conversion.
    Aug 2012
    worcester
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3.2 v6
    what could i have done wrong tho all plugs fit properly.....puzzling me
    Dec 2010
    Glasgow
    Mileage : Near 100K
    The wiring between the REC and X1 plug in the passenger footwell
    Aug 2012
    worcester
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3.2 v6
    dont suppose you have pics of what im looking for do ya i only did wiring from rear doors odd how one works one doesnt thanks
    Dec 2010
    Glasgow
    Mileage : Near 100K
    One will have the wiring, one won't.
    check the other ends of the plugs to see if you have the wiring
  1. Rear electric window
    By slipperysam1984 in forum Bodywork & Interior
    Last Post: 21st July 2011, 15:58
  2. Rear electric window kit
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2011, 02:00
  3. Rear Electric window kit
    By Big-Pete in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 3rd December 2008, 16:42
  4. Rear Electric window
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2008, 02:23
