Thread: New boot lid required - how easy is it to change?
    Regular Member Deann's Avatar
    Mar 2011
    England
    rolleyes New boot lid required - how easy is it to change?
    Hey everyone I'm in need of a new boot lid for my 08 vectra C
    I've found one local on eBay... Was just wondering how easy it is to change, and what do I need to do in order to make sure my new boot with lock and unlock as it should?
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Not done a vectra one. But if its similar to corsa then.
    Need to undo all the electrics remove wiper motor, boot lock etc.
    then you'll need a second person to hold boot while you undo the gas struts. And then remove the pins from the hinges.
    lift away and fit new boot lid.
    when I fit the locks to anything I usually operate the mechanism with a screwdriver to make sure it will operate before closing.
    have you had rear end damage?
    is boot floor etc ok?
    Mar 2011
    England
    I've not had any rear damage, I had a spoiler fitted and somebody has stolen it and made a mess of the boot and rear window, so it is cheaper for me to buy a new boot £40 than it is to repair the damage
    everything except for the boot itself is all good
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Should be easy enough to swap over then mate
    Mar 2011
    England
    My biggest concern is the boot lock mechanism
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    It's only 4 bolts and an electrical plug.
    as I say just operate it with screwdriver and it should all be fine.
  1. How easy is it to change the side skirts?
    By Vaux-Man-G in forum Bodywork & Interior
    Last Post: 4th June 2012, 23:48
  2. How easy is it to change the fuel filter?
    By PeterVV in forum Petrol Engine related
    Last Post: 29th June 2009, 21:26
  3. Is there an easy way to change the glowplugs??
    By bennettboy in forum Engine & Drivetrain
    Last Post: 13th October 2008, 14:20
