Results 1 to 10 of 13
Thread: range not working? any advice?
    Nov 2012
    london
    Vehicle : Vectra c facelift flame red
    Default range not working? any advice?
    Filled up the car to quarter tank but it says 12miles to empty, anyone know the cure for this?
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    more fuel mate lol mine does the same if i put less than 20 quid in
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    reset button?
    11 Post(s)
    Quote Originally Posted by simplesi View Post
    You've not put enough fuel in for the system to register properly.
    Regular Member wright8672's Avatar
    Spalding,Lincolnshire
    Vehicle : vectra
    Engine : 1.8
    i filled up last night and my range is only showing 330 miles,normally it goes upto about 415 miles and also only showing 28 mpg,where normally it's 35+mpg
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Range doesn't normally reset does it? Thought its purely in the level then changes slightly with driving style?
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    vectra's dont like partial fill-ups when low.
    Vehicle : vectra
    Engine : 1.8
    Quote Originally Posted by leemarksmith View Post
    normally when i fill up and start the car,the range goes to about 370 miles,then on the 8 mile journey home just over 400 miles,but after 30 miles of driving it's only now on 330 miles and mpg is well down....
    Vehicle : vectra
    Engine : 1.8
    after another 3 full tanks of fuel,still getting the same problem with low range miles and MPG displaying approx 31
    any ideas anyone
    Feb 2011
    Selby
    Reset the Range counter, as people have been saying.
    Go into the BC menu and select range (so it's the displayed value when not in the menu). Then go to Settings and do 'Reset Present'. When you do a 'Reset All' it doesn't reset the Range, so you have to select it specifically and tell it to reset. Ideally fill the tank to the top, then start the engine and reset Range and all the other counters, then drive like you would normally for 30 minutes in order for the averages to start to settle down.
    Range uses a combination of the fuel tank level and average consumption to work out the estimated distance remaining. If either of these aren't accurate (ie you've not put much fuel in or you've been driving in a non-typical way) then it won't be accurate either. The longer time period it takes an average over for consumption, the more accurate the range estimate will be. But it's only really any use if you're driving long distances at relatively constant speeds so the average fuel consumption is fairly accurate.
  1. Range??
    Last Post: 31st July 2012, 12:54
  2. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Drivers heated seat not working - advice?
    By pgilc1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 17:16
  5. range
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2007, 08:37
