Results 1 to 10 of 14
Thread: Glow plug recommendations
    Nov 2010
    Maidstone
    Default Glow plug recommendations
    Not been using the car alot the last week and shes been out in minus conditions without a start, got in her thurs and she really struggled to start, sounded like she was missing a cylinder then a puff of white smoke out the back lasting a few seconds. Now im guessing plugs could be shagged, just wondered if anyone had any recommendations?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    was the car/spanner light on at & after start up ?
    Nov 2010
    Maidstone
    No cant say it was
    May 2012
    county durham
    Mileage : 145k
    normally if a plug fails it will put the light on , could always test them in place before shelling out for new ones.
    Full Member witty's Avatar
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    Mine does exactly the same. No spanner light, then once the smoke clears, it runs fine...
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you got a multimeter?
    Nov 2010
    Maidstone
    I have but i couldnt tell easily how the wiring connectors come off, didnt want to snap anything.
    Regular Member conman's Avatar
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Quote Originally Posted by signum_rob View Post
    Just push the plastic tabs at the top, nearest you. A bit fiddley but you'll get it no problem. I just used 2 screwdrivers at each side, pushed in and pulled up. If you do need to change I use NGK and never had any problems with them. Don't use cheap ones as although they might work ok the problems start when replacing them again as they can snap very easily when removing. Also if you are replacing them, plenty of WD40 and patience's, spray the WD40 and leave it for a while and loosen off and then tighten up a bit to get the WD into the threads, plus do it while the engine is warm as they will be easier to remove
    Nov 2010
    Maidstone
    Thats the part im dreading lol
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    ha ha, I know mate..I was bricking it doing mine as I didn't know how long they were in there for. Just take your time and try not to lose it, if it cracks you up take a walk for 5 mins and contemplate on getting a garage to do it, at least if they screw up it's them who have to sort it.
    Try to use a tool that evenly applies pressure rather than a ratchet, I used this the remove mine, can be threw together with most half decent socket sets
  1. 2.0 DTI Glow plug broken :(((((
    By sinless in forum Vectra C / Signum Troubleshooting
    Last Post: 18th March 2012, 10:57
  2. Glow plug light
    By mrpoochie01 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 06:37
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  4. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
  5. glow plug light
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 17:59
