Thread: removing double din radio from vectra c
    Regular Member Daniel Dixon's Avatar
    Jan 2013
    United Kingdom
    Vehicle : vectra c
    Trim : LS
    Engine : 2.0 DTI 16v
    Year : 2002
    Default removing double din radio from vectra c
    i am having problem's removing my radio from the cage i have put the pins in and heard clicks and went to pull but the pins keep sliding out and i have the proper pins for the the radio (car 2004 cassette player) this radio was in the car when i bought it and has never worked and i now have the money for a cd version but i carnt get this one out ???
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    two things you can do here, file the lugs on the ends of the pullers to make them deeper, if that doesnt work (mine didnt ) i found that it was easier to remove glovebox you can then insert the pullers and push from behind the radio
    Jan 2013
    United Kingdom
    Vehicle : vectra c
    Trim : LS
    Year : 2002
    thanks for that mate ill give it ago. if it still wont come out you got any other ideas
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Another thing to try is gently pull each off the pullers towards Ethernet doors if that makes sense basically gently pull out wards
    whilst pulling towards you at same time. Sometimes that outward pressure helps pins hold in while you pull
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    I found that even though you hear the click you still have to push them in further. Also put some outwards pressure on the pins as you pull the stereo out.
    Regular Member caitlin6's Avatar
    Nov 2012
    worthing
    Had the same problem came out with the keys in the end
  1. installing a double din radio
    By keatsy in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2011, 15:36
  2. Removing the Radio / Stereo cage
    By Silly Car in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2010, 23:40
  3. Cant removing f***ng radio
    By nickd_m in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2008, 16:15
  4. Double Din Radio Help
    By jaxouk in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2008, 22:28
  5. How Chuffed Off Am I... Removing My Radio
    By ccsnet in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 20:26
vectra c stereo removal
vectra c radio removal
how to uninstall cd player in vectra c
Vectra c radio double din
vectra remove double din
how to remove the radio for opel vectra c
how to remove a 2003 vectra c radio
vectra 2004 radio removal
how to remove cdr 2006 fro vectra c
how to remove radio on 08 vauxhall vectra
removeradio vectra c
vectra c double din removal
remove vectra radio
how to remove double din tray vectra
remove vectra c cd player
removing radio from vauxhall vectra
vectra stereo removal
vectra c radio replacement
how do i remove vectra c stereo
removing radio from a opel vectra c
How to remove install double din vauxhall vectra c
