Results 1 to 10 of 25
Thread: Abs / traction control / no speedo HELPPPPP
    Jan 2012
    sheffield
    Default Abs / traction control / no speedo HELPPPPP
    Hi all iv got an abs / traction controll fault. Basically last night on my way home from base down country lanes the snow got worse I ended up stranded with no phone signal and no cars coming past I opted to pull the abs fues to cancel the traction controll from stopping me getting out, this ended up getting me out and managed to get me home iv had to do this before so new it would work. I put the fues back in BUT this time the fault lights are still here, iv got no speedo and carnt drive around with that.. Iv disconnected the battery to see if that will cancel them but nothing, I don't have a fault reader so how els can I cancel them off?? I never had this problem last time
    As you have disconnected the ABS module, the CIM has reset
    You will probably have to have the CIM reprogrammed
    Try this to confirm :
    Start engine, indicate left and cancel
    What happens?
    Jan 2012
    sheffield
    Ill go and check now.. This didn't happen last time.. How long should I leave it indicating for?
    Jan 2012
    sheffield
    Nothing seamed to have changed, still indicates and cancels fine, lane change still works ect
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    With the ignition off pull the plug from the abs unit under the bonnet and put it back in, its a common fault.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Remove plug from abs module.
    did you remove fuse with ignition still on?
    how bad was the snow you where stuck in?
    Jan 2012
    sheffield
    Ill give that a go in a min..
    Nooo I turned it off removed the key before I touched it.
    it was more the fact the snow had settled on ice, it was around 10cm deep
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    If you let it spin for a few secs it should go into fault mode and turn off. I find tc helpful in the snow. but I have the older abs mode that apply's the brakes and not limit rpm. Is switch able too.
    Jan 2012
    sheffield
    Removed and replaced it.. Still no change
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Is their a chance snow got deep enough into drive shaft?
  1. traction control
    By male 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2012, 14:23
  2. Traction control / ESP
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 10:56
  3. esp/traction control
    By gregzx7r in forum General Chat
    Last Post: 19th September 2009, 09:21
  4. Traction control
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 08:02
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
whatsensor controls the speedometer on vectra
