Thread: What's this
    Full Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Default What's this
    Can someone tell me what this is. Thanks
    just removed my bulb, and found that the blue bit you see on this bulb is broke , the wire that runs through it is ok. Will this broken bit cause any problems. The bulb still works
    Dec 2011
    Seaham
    It is an insulator, the cheaper bulbs do not have the insulator on them. Will still work without it, however dont touch it when the bulbs are on, you mat get a shock?
    Dec 2012
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Thanks very much. It's still on their just in 2 bits
    6 Post(s)
    Quote Originally Posted by Yidobrown View Post
    It'll be fine. The heat has more than likely cracked it.
