Thread: A code P0138 z20net
    Regular Member richy1974's Avatar
    Jun 2012
    leek
    Default A code P0138 z20net
    hi guys help please keep getting this code on my z20net p0138-02 sensor circuit high voltage bank 1 sensor 2 . What i want to know is where the best place to get a sensor from and is the one underneath the car thanks for looking any help would be appreciated
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sensor 2 yes.
    i would first suggest checking that your problem lies in O2 sensor and not the fact its a lean condition causing a rich command
    Jun 2012
    leek
    Quote Originally Posted by Critch View Post
    Sensor 2 yes.
    yes mate sensor 2
    how do i check for lean condition its be doing it since i have a a new custom stainless steel zorst fitted
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quickest way is to watch on live data whilst squirting some carb cleaner into intake.
    that should start making it rich. You should see it switch to lean command in under 100ms
    If its been doing it since exhaust fitted check connection and wiring haven't been damaged.
    Chances are it is a knackerd sensor. But it's always worth checking everything. Last thing you want to do is chuck 100+ pound at a part plus labour to find faults still their
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. P0138 Fault : Siggy drinking petrol. Help Please
    By Envy in forum Engine & Drivetrain
    Last Post: 25th April 2012, 22:18
  3. assistance with fault code please (z20net)
    By chesh1980 in forum Engine & Drivetrain
    Last Post: 8th March 2012, 22:26
  4. Replies: 1
    Last Post: 27th November 2011, 17:09
  5. Fault codes P0138 & P0141 O2 sensor
    By trampd1 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th August 2007, 10:43
p0138 vauxhall vectra
