Thread: 3.0 d Oil filter housing
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    Wink 3.0 d Oil filter housing
    Hi guys anyone know where I can get the above for a 2003 signum ? Been quoted £60 from stealer and ill have to wait over a week as none in the country !! Basically the threads on the sump plug have striped . Iv used ptfe tape and lots of metal glue as a temp measure !! Seems to being holding ok but really need to replace it for piece of mind . Even if there is a 3.0 d being scraped , can't find anything . Do any other cars have the same housing ? Rubbish design you don't even need a sump plug there you just remove the whole housing for a filter change !
    Any advi ce / help would be great .
    wirral
    58 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Take it get re tapped happened to me re tapped an a new bolt in with washer and o ring been fine since. And now I just undo filter I don't bother trying to drain out of it first.
    cost 20 quid for local engine shop to re tap it and fit new bolt
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    Didn't think the alloy would take that , must be ok if yours has lasted. Luckily I noticed the engine noise and oil light coming on and turned it straight off could have been expensive .
    wirral
    58 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Mine stripped thread when I first bought the car. 2 years ago.
    I was in same position. And tried to do it as a short term repair.
    but bloke in engine place assured me it wouldn't need replacing. And it's best to just undo the whole filter base. As they see a lot of problems like that.
    been 38k and about 6/7 oil and filter changes since and still going good.
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    well after a temp fix of metal glue and ptfe tape i managed to locate a whole new filter housing . The SAAB 3.0d is pretty much the same engine and found the housing' buy it now' on ebay for £29.99, bargin compared to £60 plus vat from vauxhall ! Thanks again for all your help
  1. help me please oil filter housing
    By kamazoo in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 22:03
  2. 1.9 Fuel filter housing?
    By Barlow in forum Vectra C / Signum Troubleshooting
    Last Post: 27th June 2012, 10:45
  3. GSI Oil filter housing
    By sickboyjay in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 15:06
  4. Vectra 2.0 DTI Oil Filter Housing
    By Jamesx81x in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2010, 16:17
  5. oil filter housing
    By andymcniven in forum Engine & Drivetrain
    Last Post: 27th March 2007, 16:47
z30dt oil filter housing
