Thanks Thanks:  1
Likes Likes:  1
Results 1 to 2 of 2
Thread: did a common fault check on 1.9 cdti 150 16v heres the results!!!
    Banned for Being a Numpty
    Jun 2012
    Default did a common fault check on 1.9 cdti 150 16v heres the results!!!
    The issues listed below are known common faults or issues with this particular model. They are not specific to this vehicle but give an indication of items you should check before purchasing.
    Problem Cause
    Engine malfunction indicator lamp (MIL) illuminated.
    Lack of power.
    Possible trouble codes stored: , , .
    Water ingress into turbocharger (TC) control solenoid.
    Instruments fluctuate, ABS warning lamp illuminates.
    Problems storing diagnostic trouble codes from wheel speed sensors.
    Failure to start.
    Poor contact between wiring harness multi-plug and ABS control module.
    Glow plug warning lamp flashes after reconnecting battery. Engine control module (ECM) software fault.
    Fuel leak from fuel filter housing.
    Diesel odour in passenger compartment.
    Fuel filter housing lid incorrectly tightened.
    ESP warning lamp illuminated.
    C0131 08
    Trouble code stored in ABS/ESP control module fault memory: .
    ABS/ESP control module software fault.
    Difficult up-change between 1st and 2nd gears, when transmission is cold. Sliding gear sticking on shaft.
    Clicking noise from front wheel when pulling away. Movement between front hub and driveshaft.
    Cracking noise from front suspension. Front suspension strut spring in direct contact with suspension strut lower spring seat.
    Gear change difficult in 1st and 2nd gear from cold. Internal fault with teeth on sliding gear.
    Rattling noise from clutch pedal area. Clutch pedal return spring broken.
    Cruise control inoperative.
    Creaking noise from C-post area. Roof panel support and webbing rubbing together.
    Non start.
    Message centre displays 'N'.
    Incorrect adjustment of brake pedal position (BPP) switch.
    Gears difficult to engage. Clutch centre plate sticking on transmission input shaft.
    Trouble codes stored: , , .
    Transmission control module (TCM) software fault.
    Lack of power.
    P2452
    Trouble code stored in engine control module (ECM) fault memory: .
    Battery discharged.
    Abnormal noise from auxiliary drive belt.
    Failure of alternator pulley clutch.
    Lack of power.
    P1901
    Trouble code stored: .
    Diesel particulate filter (DPF) blocked due to frequent short journeys or cold starts.
    Buzzing or rattling/clattering noises from gear lever when in 3rd gear. Gear lever selection cables transmitting noise into vehicle interior.
    Metallic knocking noise from RH front of vehicle whilst driving with engine speed between 2000-2500 rpm. Movement between RH driveshaft and intermediate driveshaft.
    Battery discharged.
    Failure to start.
    Air conditioning (AC) control module fault.
    Software version S3.10 and S3.12.
    Permanently consumes 75 mA.
    Information supplied by the DVLA, Police, ABI, SMMT and Autodata.
  2. Thanks nikolat thanked for this post
    Likes nikolat liked this post
  3. #2
    Jun 2012
    hope it helps a few people out,just thought it was worth sharing as i paid £2.95 enjoy
  1. Common Fault
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 00:13
  2. Help Please, 2.2 DTi Common Fault?
    By chrisschild in forum Engine & Drivetrain
    Last Post: 8th December 2010, 11:05
  3. any common areas to check for boot area rattles?
    By MCD in forum Bodywork & Interior
    Last Post: 5th August 2009, 16:10
  4. It appears its a common fault
    By gary k in forum Engine & Drivetrain
    Last Post: 17th February 2009, 10:34
  5. is this a common fault
    By don paul in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 11:21
