Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Still no heat
    Regular Member wright8672's Avatar
    Spalding,Lincolnshire
    Vehicle : vectra
    Engine : 1.8
    confused Still no heat
    had a cold running engine and no heat in car,so fitted a new thermostat and renewed coolant.
    engine is now running just a shade under 90 degrees,but still no heat from the blowers.
    also only fan speed 4 is working,so i am going to replace the thermal fuse on the resistor shortly.
    Regular Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    From cold, with the engine running, open the header tank and see if there is coolant returning to the tank.
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Sounds like a air lock I had same problem took it for a 3 mile thrashing and it cleared it
    Vehicle : vectra
    Engine : 1.8
    Quote Originally Posted by veclee View Post
    did the stat change on Thursday and done about 100 miles since then
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Are the pipes to the heater rad warm,hot?
    Vehicle : vectra
    Engine : 1.8
    Quote Originally Posted by Das View Post
    returning from where mate?
    the top smaller hose from rad to header tank?
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by wright8672 View Post
    There should be a small return pipe, the bypass pipe, that allows coolant to circulate until the thermostat opens. If you are seeing no coolant returning when cold the impeller may have fallen off the water pump. Its either that or as @veclee said an air lock.
    Vehicle : vectra
    Engine : 1.8
    yes mate,they are.
    great
    dont think this will be covered by the warranty,as i've only had it 2 weeks,so the garage i bought it from will most likely say its wear and tear
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Is they any fluid coming from the pipe What's the milage and has it had the cambelt changed
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Failed water pump should be covered by warranty. 1.8 i see from your profile, I will have a look at mine and check which pipe you should be looking for water returning from.
  1. Windscreens - Heat absorbing or heat reflecting?
    By Caveman_nige in forum General Motoring Chat
    Last Post: 4th February 2013, 22:09
  2. heat pad
    By male 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2012, 15:09
  3. we have heat at last
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 17:53
  4. No heat
    By schmuh in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2009, 23:36
  5. and then, there was heat !
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2005, 17:50
