Results 1 to 10 of 15
Thread: temp gauge problem or not ?
    Regular Member madmark's Avatar
    great yarmouth
    Default temp gauge problem or not ?
    hi i just got a 2007 cdti vectra and it takes ages for the tepm gauge to move up but the heaters do blow warm air after about 20 mins driving the gauge goes up to atound 75c but once on a open road it drops again then rises is this normal ? thank you
    Regular Member tditony's Avatar
    durham
    Vehicle : 2007 sri xpnav
    Trim : sri xpnav
    Engine : 1.9 150
    i would say thermostat stuck open mate new one required
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    your thermostat is on its last legs fella very common on the vec c diesels some change it and swear by better MPG some dont bother and say it dont make a difference im in the former camp bud
    Regular Member Albert99's Avatar
    Nov 2012
    Glasgow
    Bet ya!
    Bought a Siggy 1.9 CDTI 150 Facelift... Nearly froze to death. Changed thermostat and now it warms up quick, stays at 86 ish degrees all the time and heaters are mental hot.
    A
    great yarmouth
    thank you all for the fast replys change it i will cheers mark
    Jan 2012
    Silverstone village
    Quote Originally Posted by madmark View Post
    If you have the 1.9 120 cdti then please be warned it is a pig of a job, as the egr cooler bracket has to be removed or preferably cut off as many including myself have done, the 150 does not suffer from this design problem, so finger crossed you have the 150.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by mon View Post
    LOL - done both a good few times and yip - the 120 is a bit of a design flaw!!..
    As others have said - defo Thermostat fault. they fail open causing the engine not to warm correct.
    great yarmouth
    i have the 120 lol but there u go needs doing thanks for the warning will do it once it warms up abit out side as car is warming up enougth to use for a week or so then i sort it
    Jan 2012
    Silverstone village
    Be sure to have a read on the forum , the thermostat is held on by the egr cooler bracket, and I would strongly advise cutting the bracket, I got an angle grinder on mine in the engine bay, so not for the faint hearted, a nerve racking job.
    I would wait until the spring to do it...
    great yarmouth
    yer good idear lol the car is warming up so will leave it untill weather clears abit thank you all for your posts on this problem
  1. 2.2 se water pump/ temp gauge problem.
    By james chambers in forum Engine & Drivetrain
    Last Post: 29th June 2012, 20:31
  2. 2.2 se water pump/ temp gauge problem.
    Last Post: 19th January 2012, 02:13
  3. z18xer temp gauge problem
    By amd in forum Engine & Drivetrain
    Last Post: 30th June 2011, 19:19
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Temp gauge problem?????
    By stubopvectra in forum Engine & Drivetrain
    Last Post: 4th March 2008, 21:31
vectra takes ages to warm up www.vectra-c.com
