Results 1 to 10 of 14
Thread: Fault codes P1109 and P1110, emission light on
    Jul 2012
    Chichester
    Default Fault codes P1109 and P1110, emission light on
    Zafira 1.9 cdti Z19dth engine. Have fault codes P1109 and P1110, emission light on. Started week after manifold replacement (yes, in one year second manifold for the car).
    Symptoms: New actuator tries to move swirl flaps, but some times stucks in a half way. Restart car works fine, then new restart, and stucks again, restart works fine and then after wile stucks. Also sometimes it moves like couple mm to one and other way, and so on, wile restart a car. The actuator does the same when disconnected from flaps. Sometimes it even do not moves.
    Jobs done so far: Changed back to old actuator, still the same problem, checked wires and connection.
    Any advice? What I could miss?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    104 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Perhaps somebody will come along with a better idea, but try disconnecting the bar from the actuator (so actuator has no load on it). Engine will run fine without control of the swirl flaps. See if the fault code goes away after driving for a while.
    If it does, then suspect sticking mechanism (though not sure why on a new manifold!). If the code persists then perhaps there is a weak/intermittent electrical connection to the actuator.
    Jul 2012
    Chichester
    Today had a little bit more exploring. Opcom test for actuator looks like this (tha same for both actuators new and old)
    Test 1 http://youtu.be/ub4dM2vCzlY
    Test 2 http://youtu.be/o3EM3c9JIiM
    the readings from opcom test is: 1) 5 and 95, or
    2) 5, 10, 5, 10 etc. Even when test is not active the readings are like this.
    Also the EML light comes up when driving, but no fault codes saved. When EML light on and scan for faults it gives P1109 0r P1110 or both. As soon EML light dissapears (by it self) there is no fault codes stored on ECU
    The EML light comes up also when engine is on,and no acceleration or any other movement at all. Also disappears by it self.
    Anu Ideas?
    Also the same readings and lights is with actuator disconnected from flaps
    Admin plasma's Avatar
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    please be aware that doing an actuator test can only be done a certain amount of times before it damages the motor, think its 4 or 5 times according to TIS/Tech2
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jul 2012
    Chichester
    ok, but why brand new actuator did the same ( no tests done before), started in 200 miles after a change
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    cant tell you why, but i suspect the same as what already been said, something iffy with your new manifold.. disconnect the bar from underneath and see if u move it manuall whether it feels like its sticking
    Jul 2012
    Chichester
    iT moves freely, and when actuator is disconnected, still have a codes and light coming up
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Sorry - but to be clear - did you install a new actuator when the inlet was fitted?
    Jul 2012
    Chichester
    Quote Originally Posted by AntSSSS View Post
    Installed new actuator. The problem started after a week of changing both of them. Made approx 200 miles.
    After fault codes, garage decided the new actuator is faulty. To check that put a old back, and the same problem.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Quote Originally Posted by kristapsl View Post
    Code:
    P1109 IAT - B Sensor Intermittent
    P1110 IAT Sensor (D/C) Open/Short
    IAT = air intake temp.
    I don't know if you already knew that or even if that helps you any.
  1. fault code p1110
    By m19hud in forum Engine & Drivetrain
    Last Post: 25th November 2011, 11:22
  2. mil light on three fault codes
    By peter carvill in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 08:44
  3. V6 CDTI P2108 and P1110 fault code help
    By finnyhaggis in forum Engine & Drivetrain
    Last Post: 6th February 2011, 22:59
  4. Emissions Light- Fault Codes
    By Stu_2010 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 21:06
  5. 2.0T Sri Emission Warning Light - Fault Code 0038
    By Brooky18 in forum Engine & Drivetrain
    Last Post: 15th August 2009, 18:48
vaux astra 1.9cdti fault code p1109
opel error 1110
p1110 opel
astra gsi p1109
vectra p1109 iat sensor intermittent
p1109 fault code
p1110 vectra v6
