Thread: a different hid question
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Default a different hid question
    Can anyone tell me how much juice hids pull compared to ordinary halogen bulbs
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    they pull like 22,000 volts or something ridiculous like that
    Jun 2011
    Vehicle : vectra
    Year : .....
    How does this affect battery performance reason I ask did a load of short runs yesterday all with lights on and in very cold conditions after about the tenth start of the day battery flat needed a jump start
    Dec 2011
    liverpool
    6 Post(s)
    i dont think it does have an affect on the battery might just be the age of the actual battery how old is it do you know ?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Should only be the same as their capacitors and ballast resistors to up the voltage.
    short runs is your answer.
    think of your battery as I'd its a bank account it takes a lot of cash to start it. If you keep taking and not putting any back you soon run out of cash
    Jun 2011
    Vehicle : vectra
    Year : .....
    Yeh short runs and I think the battery could be the original time for a new one,cold spell sorts them out thanks for the info fellas appreciated
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    A quick trip to Halfords will get you a free battery check.
    and because they sell bosch battery's they use a bosch battery tester.
    which are some of the best in the market. If that thing gives a print out saying you need a new battery. You need a new batt.
    Jun 2011
    Vehicle : vectra
    Year : .....
    [QUOTE=Critch;1969361]A quick trip to Halfords will get you a free battery check.
    which are some of the best in the market. If that thing gives a print out saying you need a new a
    battery. You need a new batt.[/QUOTE
    That I will do as soon as I can dig the car out of the white stuff
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    The hids have a wattage 35 w or 50/55w, if its the original battery and short journeys as said thats ure answer I would dich it and get a s5 Bosch battery, but there alot cheaper from eBay but if u go into halfords and see what one u need so you know what u are looking for on eBay :-)
    Dec 2011
    Seaham
    You can calculate the current draw using this simple equation
    Power = Volts X Amps
    Hence we know the draw on the lights as they are statd to be 35 watt and it is a 12volt suply (although it does increase to 14 volts with the enine running)
    Re-arrange the equation
    Amps = Power/Volts, so in this case 35 watts divided by 12 volts in under 2.92 amps per side.
    55 watt halogens would draw 55/12 = 4.58 amps per side.
    You can use this equation when calculating the wire size you need to use for accessories. But you always need to have a safety margin and I would add 25%.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
