Hi all,
As title states, is it same engine? VP44 PSG16?
I will have log book from donor car, so can get pump codes from local dealer. But just to confirm is it the same engine?
Signum was Y22DTR.
Thanks in advance.
Hi all,
Signum was Y22DTR.
Thanks in advance.
No, the Vec B used a different fuel pump (or at least different ECU). There may be some other slight changes too. It MAY be possible to fit your fuel pump and injectors to the Vec B engine but I'm not sure if that'll work.
the inlet manifold is different but you can change over parts from yours as they have the same block and head and as said above the pumps are different
what was wrong with your engine
Thanks for replies.
That Vectra B engine is Y22DTR, is it still different pump? no luck then... Old engine have dead pump, just won't fire up. There is 130K on that engine, so been advised that swapping engine and reprogramming pump would be just easier then.
do a search someone on here fixed the pupm for very little
i know the feeling man i had 1 die a few years back
How about saab engine 51reg? Y22DTR, the same?
