Thread: Vectra (B?) 51reg 2.2 DTR engine into 53reg Signum
    Dec 2012
    Worthing
    Default Vectra (B?) 51reg 2.2 DTR engine into 53reg Signum
    Hi all,
    As title states, is it same engine? VP44 PSG16?
    I will have log book from donor car, so can get pump codes from local dealer. But just to confirm is it the same engine?
    Signum was Y22DTR.
    Thanks in advance.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    No, the Vec B used a different fuel pump (or at least different ECU). There may be some other slight changes too. It MAY be possible to fit your fuel pump and injectors to the Vec B engine but I'm not sure if that'll work.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    the inlet manifold is different but you can change over parts from yours as they have the same block and head and as said above the pumps are different
    what was wrong with your engine
    Dec 2012
    Worthing
    Thanks for replies.
    That Vectra B engine is Y22DTR, is it still different pump? no luck then... Old engine have dead pump, just won't fire up. There is 130K on that engine, so been advised that swapping engine and reprogramming pump would be just easier then.
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    do a search someone on here fixed the pupm for very little
    i know the feeling man i had 1 die a few years back
    Dec 2012
    Worthing
    How about saab engine 51reg? Y22DTR, the same?
  1. My Signum Engine
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2014, 16:30
  2. best vectra/signum engine to buy on a 54 plate
    By daniel1990 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 15:29
  3. 1.8 sri 53reg Coolant temperature
    By otto in forum Engine & Drivetrain
    Last Post: 9th May 2009, 13:07
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. power loss when driving in a 2.0dti 53reg
    By 1rsm in forum Engine & Drivetrain
    Last Post: 29th December 2007, 19:34
