Results 1 to 10 of 20
Thread: wiper lever replace 1 with bc function
    Jun 2012
    Oude Pekela Netherlands
    Vehicle : Opel Vectra Z1.9DTH stw
    Default wiper lever replace 1 with bc function
    A good friend of mine has replaced his original radio for a double din pioneer. Now he can not operate his his BC. There are Vectra's's where the BC can be operated with the wiper lever.
    Is it possible to replace the wiper lever. For a lever with BC function.
    Vectra's GTS 2.2 diesel 2003. steering wheel controls with buttons.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Does it not work by pressing left hand scroll buttons?
    Jun 2012
    No according to him not
    11 Post(s)
    Quote Originally Posted by Helmer79 View Post
    6 buttons, or 4 buttons and 2 scroll wheels?
    Being a 2003, I suspect 6 buttons (half canbus) - in which case you can't access the BC function from them.
    If he had a fuel computer, then he should have already had the relevent buttons on the wiper stalk.
    What was the original stereo that was fitted?
    Jun 2012
    The NCDC 2013 radio.
    The steering wheel control with 6 buttons
    No he has no buttons on the wiper lever
    crook
    Yes you can fit wiper stalk with buttons.
    its will need tech2/opcom programming in.
    Its hit or miss if it will work, some do some dont.
    Depends what head unit is in now and what adapter leads are used
    New Member ronnie opel boy's Avatar
    Feb 2012
    holland
    I buy a 2 the handse try that thank it comes to my vectra c
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    As far as i know, the NCDC head unit has a button on it to access the BC functions, and being half-canbus, you should be able to put in the BC wiper stalk and program it in using Tech2/Vauxcom/*the unmentionable*
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    As mr derv says code index needs changin add the stalk job done
    Jun 2012
    Is that possible with Op-com
  1. BC - no function
    By dmcc in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2013, 20:12
  2. enable bc function on wiper stalk
    By anas in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 11:33
  3. Winter Wiper Safety Function
    By Signum7060 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 19:30
  4. Can the egr function be deleted from the ecu?????.
    By felixx in forum Diesel Engine related
    Last Post: 26th February 2011, 18:56
