Results 1 to 10 of 29
Thread: Car won't start and ticking again
    argyll, scotland
    Default Car won't start and ticking again
    Ok so as per previous thread where car died and wouldn't start again and just kept ticking I put a new battery in on Monday and started first time no problems, today after a 2 hour trip got home and went to start the car again and it's back ticking again
    ive tried jump starting it, disconnecting the thermostat sensor and bleeding the fuel filter but still titicking I just need to get it going again so I can get it traded in and wash my hands of it.
    my first thought is to fully charge the battery from a battery pack and hopefully that'll get it started enough for me to get it to the garage
    any other ideas ???
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Alternator?
    What is voltage at battery?
    argyll, scotland
    Alternator was replaced a few months back, will check the voltage in the daylight
    was maybe thinking glow plugs or possibly fuel filter
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    does the car turn over or just click
    argyll, scotland
    Turns over slightly and then just really fast clicks
    Dec 2011
    Seaham
    Could be a faulty starter motor?
    Nov 2012
    Birmingham
    Jump start it with another car, same happened to mine.
    Are you VXR Enough
    13 Post(s)
    sounds like the alternator isnt charging the battery properly but you need to put a multi meter on the battery and see what the volts measure and then do it again with the engine running and then switch on the lights heated rear screen etc and then test it again
    argyll, scotland
    Tried jump starting and just kept ticking, just went out there and there's hardly any ticking now and the dash is like Blackpool illuminations or sometimes just goes blank then all lights up and f in the display and just a constant whirring coming from the rear by the sounds of it, just bizzare
    tried putting it in gear and rocking it there but nothing, have disconnected the battery negative to see if it'll reset the ecu but I'm stumped
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    35 Post(s)
    Engine : 1.9 DTH
    Is known to alternator to fail again , as said above check the voltage first...
  1. Replies: 9
    Last Post: 15th January 2013, 14:16
  2. Slight ticking on start until warm on 1.8club?
    By GazSwansea in forum Engine & Drivetrain
    Last Post: 7th May 2011, 23:22
  3. Ticking and loss of everything :( HELP
    By sjboyington in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2011, 07:02
  4. Engine ticking for 30 secs after start up
    By clive3373 in forum General Chat
    Last Post: 2nd May 2009, 22:24
  5. Ticking
    By jimsoft in forum Bodywork & Interior
    Last Post: 3rd September 2007, 22:25
