Results 1 to 10 of 14
Thread: SRI Standard ride height
    East Ayrshire
    Trim : SRI XP1
    Default SRI Standard ride height
    Is anyone able to tell me (Or measure) the ride height of the sri cdti as standard? I'm convinced mine is def too high. From wheel centre to the arch it is 38cm. Anyone able to give me an idea if this is right or not
    Regular Member grabos's Avatar
    Aug 2010
    Coventry
    I'm sure I've seen another thread not long ago where people posted their veccys ride heights for an sri before and after lowering
    I think it was something like 35cm rear and 37cm front (approx) for a standard sri
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    158 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Quote Originally Posted by stevie16v View Post
    Ask @antowens , I know he only just measured his
    East Ayrshire
    Trim : SRI XP1
    Ideal guys. Thanks very much
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    right i have just found my notes and mine is 37.5cm or 375mm on the front so 5 mm or half a cm isnt that bad and my rears are at 355mm (35.5cm) hope this helps
    East Ayrshire
    Trim : SRI XP1
    Ideal mate, thanks
    Jul 2012
    Greece
    One question, i fitted eibach pro kit on my GTS (Sri) and the front is 1 finger higher (from wheelarch to tire) than the rear, is that normal ?
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Mine is a bit higher too, but still too low, as proves the way my front bumper and spoiler crashes on the ground when going down bumps or ramps.
    I have 360 mm front and 355 mm rear (so still a bit higher at the front than the rear), which is actually too low considering the bad local roads (an streets), but the worse is the front suspension is way too soft. I'll probably fit lowering springs, not to lower the car (seems it can't get worse as now), but to stiffen the suspension.
    The 8x19" ET35 rims also probably apply too much torque, so the right springs for my settings (2.2 DTi with manual gearbox and air con) would probably be the heavier 3.0 CDTi ones (which are the correct replacement part numbers anyway, according to the maker's catalog). I'll try this first, then go for uprated (for 3.0 CDTi) Eibachs if I'm still impaired with too soft springs on our (very) bad roads.
    East Ayrshire
    Trim : SRI XP1
    I got replacement springs from eibach. it was the wrong ones they had sent me. Its now sitting at just over 360mm so happy with that
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I assume they sent you the 1060+ kit, rather than they up-to 1060 kit?
  1. vectra cdti sri standard ride height
    By hamish123 in forum Handling & Braking
    Last Post: 14th January 2011, 19:58
  2. ride height
    By pidge in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 17:59
  3. SRI ride height ??
    By Mickyboy in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2010, 12:05
  4. standard ride height
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2010, 22:59
  5. GSi ride height
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 9th February 2008, 18:21
vectra c ride height
ride height on vectra 3.0 cdti
gts vs standard height vectra
