Thread: temp
    Regular Member HARRY SRI's Avatar
    liverpool
    Default temp
    i have a facelift vec-c 150 cdti,it's taking along time to warm up in this cold weather,why?
    Regular Member stret's Avatar
    Oct 2012
    east midlands/westmidlands
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 16v 225bhp
    Year : 54
    Mileage : 150k
    how long? prob thermostat, think there was a thread with someone with this prob yesterday or day before
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Ambient temperature is much lower and people say Diesels take a lot longer than petrol to heat up, but everyone who took the plunge and changed the thermostat found it heats up much quicker, even the non believers.
    When it does heat up does it stay at a constant temp or does it fall away when driving, or with the heater on, and rise when stopped in traffic?
    11 Post(s)
    Duff thermostat - as others have mentioned.
    Regular Member Albert99's Avatar
    Nov 2012
    Glasgow
    Bet ya!
    Bought a Siggy 1.9 CDTI 150 Facelift... Nearly froze to death. Changed thermostat and now it warms up quick, stays at 86 ish degrees all the time and heaters are mental hot.
    A
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    :: Need a new thermostat
    May 2012
    UK
    My vvt warms up to operating temp no probs normally. In this weather if I go over 60 on the motorway it also gets up to temp no probs, heaters are hot etc.
    However I've noticed in cold conditions if I then go on a smaller road doing a slower speed around 30mph the temp will actually drop down, particularly within the first few miles of setting off Is that normal?! I have the fan on hot if that makes any difference?
    I don't have any other temp-related issues...
    Regular Member wright8672's Avatar
    Spalding,Lincolnshire
    Vehicle : vectra
    Engine : 1.8
    i have just changed the stat on mine,engine temp is fine now,but still have no heat in the car.......great at this time of year
    Dec 2011
    Seaham
    Chip
    I tink the electric thermostats on the VVT's are very sensitive and hence the changes in temperatures of the engine, if you continued to drive at the slow speeds the temp would come back to the 90 degrees.
    If you look at the How 2 I completed on changing the thermostat, you will see it is operated by a solenoid rather then the slower moving traditional wax type. I think the solenid operates quicker then the wax ones, thereby giving the sudden drps when channging the driving speeds.
    May 2012
    UK
    Quote Originally Posted by Ben50n View Post
    Chip
    Cheers! I tried it today and it seems ok, once up to temp it stays solid at 90 degrees. It seems if it's not fully warm it can drop down when the heaters are on.
  1. What's your temp at?
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 22:14
  2. What temp should air con be ?
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:49
  3. DTI temp
    Last Post: 23rd September 2010, 22:53
  4. outside air temp
    By leeashford in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 19:34
  5. temp
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2009, 13:52
