Thread: Handbrake problem - advice please
    Jul 2012
    Beccles, Suffolk
    Default Handbrake problem - advice please
    Hi folks,
    I've had a strange problem with my handbrake today and hope you can offer some advice.
    I pulled up the lever as normal and it came all the way up but hadn't put the brake on.
    I tried a few times and sometimes it acted as normal and put the brake on and sometimes it just pulled up with no resistance
    I have read about the handbrake recall and checked with my local dealer who said that mine had been "modified".
    What should I be checking?
    John
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The 'handbrake recall' concerns replacing the spring behind the thumb button with a meatier one as there was a chance the original weaker spring might allow the mechanism to slip.
    As to what's occurring with yours, I can't be much help. My guess would be that the mechanism (probably at the rear calipers) is jamming of frozen - sometimes it is releasing as normal, sometimes the mechanism jams and you just get a slack cable.
    Weather permitting I'd be having the rear wheels off and thoroughly checking and cleaning the calipers and handbrake mechanisms.
    Aug 2010
    Leeds
    Take the handbrake off on the flat surface and pump the brake pedal hard it should auto adjust and reset the rear pads.
    Mine does this it's a farce untill you can have a good look at it in warmer weather.
    Jul 2012
    Beccles, Suffolk
    Many thanks guys.
    It's a bit snowy here and the car sits in the drive (not on a slope thankfully !) so I'll be having a look when the snow goes.
  1. Handbrake problem
    By Razzemup in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2012, 10:45
  2. HandBrake Problem
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 21:28
  3. Handbrake problem.......
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2009, 18:37
  4. handbrake advice needed
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2008, 13:34
  5. That 'ol handbrake problem
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 21:44
