Results 1 to 3 of 3
Thread: How To: Better Numberplate Lights
    New Member switswoo111's Avatar
    Jul 2012
    lincs
    Default How To: Better Numberplate Lights
    Thought I'd create a How to as one day I decided to Change my signum rear number plate bulbs to led type.
    After noticing that the old plastic lenses were faded and dirty on the inside and almost a yellow colour I figured a clear lense would be better, also the metal contacts are fixed into the holders and make contact when fixed in place. Ie No wires to fiddle with, so to get around this problem I did this......
    After eventually screwing, drilling and prising out the rusty screws I removed the old plastic lamps.
    With a fine hacksaw and wearing gloves gently saw off the top of the lens from the bulb holder part. One side of one of mine did snap off but superglue is your friend.
    Then I ordered in a piece of 2mm thick clear acrylic perspex (100mm x 100mm) is suffice. Then Cut 2 strips the width of the old lens, scrape the edges smooth with a craft knife.
    Then glue the removed holders with attatched metal contacts to the centre of the perspex pieces.
    I didnt screw mine to the car as I was scared of cracking the lenses, so I covered the back of the holders with strong double sided foam tape and fixed into place! With 39mm 16 Led festoon bulbs and is as bright as anyone could want
    I hope this helps someone and you give it a go yourself if you like this mod Thanks
    Regular Member farley2708's Avatar
    antrim n.ireland
    Manfred Mann song springs to mind fella............................................. ....................'blinded by the light'
    'officer,the number of the car i saw speeding away from the robbery at 3.30 am was k777 lay'
    very nice job on making new lens covers
    Jul 2012
    lincs
    Yep, deffo see me "Going" Thanks
  1. Numberplate lights
    By Nick82 in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2013, 22:54
  2. numberplate lights
    By Angel1368 in forum Styling
    Last Post: 17th April 2012, 13:10
  3. Numberplate lightbulb
    Last Post: 1st January 2012, 21:26
  4. interior and numberplate lights
    By redross555 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2011, 20:58
  5. LED numberplate bulbs
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2009, 09:32
